RR 02-01-2011 Release
  • RR 02-01-2011 Release
    Holly CR/\P its February already!!
    Download HERE
    Not much here, a tweak or two...
    Some Highlights:
    • NetRadioArt
    • Skincommand; "RESTORE" restores RR window (from minimized)
    • Winamp Player Play list file name option; "*.extinfo.m3u" or "*.extinfo.m3u8"
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    1/29/2011
    + Winamp Player Play list file name option; "*.extinfo.m3u" or "*.extinfo.m3u8"
      If the file name of the play list loaded into RR ends like above, its
      passed directly to winamp, vs RRs existing method. Therefore all paths
      to audio files must be correct or they will not play. Best used for URL type
      play lists.
    1/21/2011
    + When playing a URL (Net Radio), Albumart will attempt to use:
    	"NetRadio_xxx.xxx.xxx.xxx" where xxx.xxx.xxx.xxx is the IP/URL.
    	Using .png or .jpg or .gif as extension.
    	NOTE: : and / are translated to .
    	examples: http://82.201.100.23/Radio538 becomes "NetRadio_82.201.100.23.Radio538"
    					 	http://216.155.137.150:8000 becomes "NetRadio_216.155.137.150.8000"
    	when a URL image file is not found, the albumart will default to:
    	"NetRadio.png" (remember, .jpg allowed too).
    	These images are stored in the folder: "NetRadioArt" (from RR ROOT)
    1/19/2011
    * Minor tweak to Silabs radio, TA signal must be valid for 1 second before ONRDSTASTART is fired.
    * Minor tweak to HD Radio, since no stereo indicator is provided by tuner, its faked if Signal Level > 50%.
    01/11/2011
    * Desktop Composition is disabled by default on Windows 7, setting, if existing install
      you might want to consider setting it to false in rr.ini (DisableDC=false)
    # Added proper Activation focus back to skin when dimmer is activated
    + "MediaCarExecTBL.ini" this file is read in with global Exectbl.ini to add
      some commands that the OLD mediacar front end supported, and are obsolete in RR, while
      these commands could have been added to existing ExecTBL.ini at anytime by anyone
      they are all now in this file.
    01/04/2011
    + Skincommand; "RESTORE" restores RR window (from minimized)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Cool
      Just curious, how does one invoke the "RESTORE" command if RR is minimized?
      Project completed! (almost)
      My Truck as featured in Custom Classic Trucks magazine.
        I use this in RRVoice. Put this in the menu.ini file-------> Restore=Restore or Maximize=Restore. Works great! Thanks mitch.
          Just for anyone wanting to copy and paste, they need to be on different lines, but you can have both:
          Restore=Restore
          Maximize=Restore
          My Fiero Build Thread
            Clsetimg
            I should like to know how to use the CLSETIMG option into a custom list.
            I wanted post this question into the RoadRunner thread but it is dead into this new forum version
              Custom Icon
              Here is the line from my skin. I have a CL in my menu.skin
              The custom icon is called select.png which should be in your skin folder. You can name it what you want, just change the line to your needs, then it will show that file in your CL.
                Thanks for that Mitch
                New Car PC Build list in progress
                  I know that,but thanks.
                  I should want to have a different icon by line.
                  I know this possiblity:
                  0
                  LSTLine1||This is line 1
                  LSTLine2||This is line 2
                  Does exist another method ?
                    The only methode for different images in Custom Lists is this command.
                    "CLSETIMG;1;$SKINPATH$ListIcon1.BMP"
                    "CLSETIMG;2;$SKINPATH$ListIcon2.BMP"
                    "CLSETIMG;3;$SKINPATH$ListIcon3.BMP"
                    "CLSETIMG;4;$SKINPATH$ListIcon4.BMP"
                    "CLSETIMG;5;$SKINPATH$ListIcon5.BMP"
                    Now you can have 5 differnt icons in the list.
                      If your CL is gonna have a lot of lines, then creating a text file for making the list and using "CLLOAD" would be the more efficient and quickest way for RR to load and display it verse adding line & image one by one to the list.
                      Good for a big list of items:
                      0
                      Good for a few items:
                      "CLADD;Line1;This is line 1"
                      "CLADD;Line2;This is line 2"
                      "CLADD;Line3;This is line 3"
                      "CLADD;Line4;This is line 4"
                      "CLADD;Line5;This is line 5"
                      Next in line: RRMedia v2.0
                      DFX 5.1.1 Skin
                      Appstore Link
                      My RideRunner Plugins
                      RRMedia
                      RRExtended
                      DFXVoice
                        How i use this example ?
                        Into a skin file ? Or into my exectbl.ini file ?
                          Depends on what and where you are adding the items from
                          DFX 5.1.1 Skin
                          Appstore Link
                          RRMedia
                          RRExtended
                          DFXVoice
                              Hey Mitch,
                              Is there a command to save "radiolocal.ini"? I have completed my RRCode/GPSExec routines that automatically change radiolocal.ini as soon as I'm within 60 miles of select cities and for those not already stored I have programming to scan the local channels and save to a file Radio"CityName".ini. Unfortunately, unless I switch away from the radio and return, if something happens, like system crash or shuttdown, its not saved to radiolocal.ini in the RR Directory.
