problem with "WRITETOFILE"
  • problem with "WRITETOFILE"
    Hello,
    I have a problem with the "WriteToFile"
    When I write this:
    WriteToFile; $SKINPATH$ toto.txt; = "toto, toto, toto"
    and when I open the file toto.txt, there to write it:
    "tot
    In fact I think we can not write a comma in quotes because when I put the same function without any point he writes well in the txt file.
    example:
    WriteToFile; $SKINPATH$ toto.txt; = "totototototo"
    here is what he has to file toto.txt:
    "totototototo"
    It's good that the problem is the comma, is there a solution to this problem?
    Greetings.
    put in skin.ini
    com=,
    then in your "toto$com$toto$com$"
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      YESSSS
      thank you very much, I tried it in a variable, but it did not work.
      in skin.ini is ok.
        NO PROBLEM here,...
        this works fine
        WRITETOFILE;E:\TEST.INI;="BLA,BLA"
        in my file is:
        "BLA,BLA"
        since you provide no information, i can only suggest use the newest riderunner
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          Now, why on earth would you need "BLA,BLA" in a skin file?
            I do not want to write to a file. INI, I want to write in a txt file and confirm that if we do not place the comma in the ini file, it does not work
              sure it does!
              WRITETOFILE;E:\TEST.txt;="BLA,BLA"
              will write, to a file named "test.txt" on root folder of drive E, with the contents:
              "BLA,BLA"
              (including the qoutes, which must be there if you want , inside)
              and again, since you provide no infomation, i will suggest you use the latest riderunner
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                The issue here is the use of comma WITH quotes in the manner you're using. Generally you should have no issue but if you do, you can use this trick:
                "SETVAR;COMMA;,||ADDTOFILE;C:\Test.txt;="boo$comma $boo"" however these versions should work directly without needing anything:
                "ADDTOFILE;C:\Test.txt;='boo,boo'"
                "ADDTOFILE;C:\Test.txt;="boo","boo""
                If you execute the command from a plugin/script (i.e. skintool) it should work in the original format. It is just hard to think of all the possible uses for the command when we make it.
                Ride Runner RR's Myspace
                  Thank you Guino
                  I have another problem, I just installed on my PC windows7 home, but when I run RR, there must be problems right director, because I normally IBUSRR which launches at startup with the "RUNQ "in Exectbl.
                  But it does not start, so I tried to boot RR as an administrator, but it does not start.
                  By cons with Skintool run as administrator, it works, it nevertheless starts IBUSRR.
                  No problem in XP
                    rr when started will automatically ask for elevation... its built into the manafest... if you set it .exe to run as admin, you wont get nagged
                    but that has nothing to do with IBUSSRR... which is 3rd party
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      From what you said it seems you installed RR as a regular user (not admin) and now you're trying to run it as an admin user ? I would recommend disabling UAC, uninstalling it with the regular user and installing it as administrator (which you will use to run it). I have done no testing on running RR as a regular user, or even worse, installing it as one user and running as another.
                        topjohn, IBUSSRR may not be a UAC compliant program, my suggestion is turn off UAC for you car pc
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          Besides, who needs UAC in a carpc anyway....
                          Next in line: RRMedia v2.0
                          DFX 5.1.1 Skin
                          Appstore Link
                          My RideRunner Plugins
                          RRMedia
                          RRExtended
                          DFXVoice
                            dead on!
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              But what is strange is that at home I am administrator of my machine (with all admin rights).
                              In my car I'm still running XP, so I have no problem.
                              It does not bother me that IBUSRR does not start at home (since I do not ibus at home), but I said if this problem exists with the launch of the command runq IBUSRR with windows 7, then it can happen with another program ...
