upgraded to 2/1/2011 and...
  • upgraded to 2/1/2011 and...
    i just upgraded from 1/1/2011 to 2/1/2011 and all my directory lists now show their file extensions when they previously didnt. of course all my SD's say FALSE for 'Show File Extension' (I've also tried 0).
    they used to be hidden, i upgraded and changed nothing, and now they show and wont go away.. same for all the screens with directory lists... any ideas?
    can i see a SD definition...
    there are no changes in 2/1/2011 release on "SD"
    here is one of mine:
    Code:
    SD,00,00,32,32,"$RRDATAPATH$Plugins\RRMJSGUSBLED\Scripts","*.led",False
    and the result
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      yeah i didnt think there would be any change in this... ugh hello full uninstall/reinstall
      thanks
        no, i wouldnt do that!
        that implies there is an issue with our installer!!!
        i see my attached image is lost today... was there last night
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          reverted back to 1/1/2011 and its back to normal. weird
            again, ill ask for your example...
            the example "SD" please
            ---------- Post added at 05:05 PM ---------- Previous post was at 05:03 PM ----------
            not to mention this setting in rr.ini
            showextensions=true|false
            This sets whether to display file extensions on Directory Lists: true=show, false=don't show
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              SD,00,01,15,30,"$ShoppingItemsDirectory$","*.*",FA LSE
              and in rr.ini:
              showicons=true
              showextensions=false
              EDIT: had these same settings for both versions of RR and 2/1/2011 didnt work. doesnt matter tho, i've got it working with 1/1/2011 and im happy
                i just installed 2/1/2011 and that SD line shows NO extenstions...
                i put c:\ for the path as test
                so... im not sure, if u can attach files, can u attach the .skin file... maybe email it to me ill pm my email
                i just added
                SD,00,01,15,30,"C:\","*.*",FALSE
                to list.skin in carwings_dynamic_light, then did "load;list.skin"
                and no ext
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  its no big deal.. honestly at this point id have to uninstall my current version and redo my settings in the 2/1/2011 version only to probably uninstall and come back to where i am now. it works, im content, it was just really weird. thanks for your help and cooperation tho, always appreciated at this place
                    then you wont be able to forward with that approach
                    and what settings change? there should be NO difference between 1/2011 and 2/1/2011 versions settings
                    i can assure you there are bug fixes and improvements going forward, and you might want them
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
