Visualisation won't embed
  • Visualisation won't embed
    I've upgraded to one of the latest versions of RR (will check version tonight), as I was having trouble with album art being displayed. This is now fixed however I have now noticed that the visualization will no longer embed. Confirmed it's not working with both Carwings and the Crystalblue skin I am using. Using winamp AVS. Was embedding fine before the upgrade - in crystalblue the albumart areas is the same as the viusu area.
    Any ideas where to start?
    in carwings, visu is set as a transparency type... (AVS set as visual in winamp v5.6 classic)
    in Carwings_Dynamic_Lite folder, in skin.ini:
    visuname=!Winamp Gen!AVS
    transparentvisu=true
    opacityvisu=40
    these will override any rr.ini settings for this skin...
    and as you can see.. works great!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Cheers, will give it a try
        its not really try, cause what i was saying, this is how carwings is set up, all you have to do is set winamp to use AVS
        might need winamp in classic mode, i dont know, but it should just work
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          hmm, still having no luck. using RR version with last history.txt entry of 12/18/2010/
          using winamp v2.95
            thats older, oh and the images i dont see... forum issue i guess...
            winamp 2.95 could be your problem, thats like 10 years old
            maybe AVS window name is different on it, i suggest the newest winamp
            install in classic mode
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
