Menu popups with transparancy and you
  • Menu popups with transparancy and you
    RideRunner 3-1-2011
    so.. how do you make popups like
    just a FYI, in the new Carwings_Dynamic, if you edit skin.ini
    [ Use Exit Menu ]
    cwUseExit=True
    you will see the new look exit menu
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Awww, come on guys, it's so simple maybe you need a refresher course. Heyya! It's all ball bearings nowadays.
    ok, to make these, its just png of course...
    the layers
    the EMPTY: it must be named ending in _transparent, so.... myskin_transparent.png or My_Menu_Transparent.png
    so in skin file
    line 3, image definition line:
    exit_menu_transparent.png,exit_menu_off.png,exit_m enu_on.png,exit_menu_on.png
    simple enough, it can be an menu you want, ie must be used with the "menu" command
    RideRunner Skin
    RRScreen my_menu
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
      Show off lol...
      Riderunner / Genesis
      Wifiman_NET:Version 1.0.0
        Very nice , i love
          I like nice and sleek
            it is possible to use this option with other .skin file ?
              course
              this is just an example...
              its with any MENU;blabla.skin
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                already using feature this in RRGameStation. Very smooth
                Live mp3Car Facebook Chat
                  Ho i see how to now !!!
                    I have not found this exemple into the 4/1/2011 SkinCommands.txt file.
                    Can you add it please ?
                    Big thanks
                      hi mitch,
                      i work with this new function...and it works very well.....but....the notes for it inside the skin commands.txt are not well.
                      the notes inside telling me that POSx and POSy are relative to the values inside the general.ini.
                      thats only the half truth. its when you fix the value -0- (PosX=0) your object would be place in the center of your screen.
                      if your object has the same width as your screen, its no problem...but, the Y position is also in the center.
                      if its your willing to place the object in the center...its ok, but please give a note inside skincommands.txt file.
                      a second question about it,
                      my skin is 800x600 pixel, the object i popuped is 800x450 pixel. if i poped it, no other label, button, slider aso. i canīt change.
                      so i must wait that the fixed timer is ended, or go my way and put a CANCEL command also in it.
                        and another thing with popups.
                        they didnīt work inside the videoplayer skin.
                        if you popuped an object, the skin goes to full solution and blocked all other grafics.
                        if you ended the popup, the video screen will not be refreshed, so you have the rest of your popup graphic on the screen.
                          The part about the popups in the video screen, that's a bit complicated already....little alone adding support for different popups... guess we'll see what mitch has to say
                          Next in line: RRMedia v2.0
                          DFX 5.1.1 Skin
                          Appstore Link
                          My RideRunner Plugins
                          RRMedia
                          RRExtended
                          DFXVoice
                            hi blue,
                            yeah i will wait what mitch says.
                            i had a lot more questions
                              yes, popups are complicated on video
                              remember its not live!!
                              the transparancy is done via a capture of the background, and may not even work
                              right on top of video
                              which is already a window ontop of rr
                              so... i dont know what happens, but i wouldnt recomend to use them on top of video
                              i would make a small popup and try
                              as for the position data, im not sure, nothing is new about them, i dont doubt its hard to understand in skincommands.txt
                              hopefully someone else will clearify
                              the popup is modal
                              if you want it to go away
                              used the new idle
                              this in the skin file
                              IDL,10,"CANCEL"
                              this will execute "CANCEL" command after 10 seconds of IDLE.
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
