3/1/11 popup /xpos /ypos
  • 3/1/11 popup /xpos /ypos
    The new popup menues are great, however, updating from 2/1/11 to 3/1/11 changes the popup location in the skin for no reason. As you can see in the screen shots. The first is the Audio_Player.skin loaded. The second one shows the popup menu, (in the red rectangle) at its programmed position, /POSX=410, /POSY=336.
    The second one is RR 3/1/11 with the same skin and popup (/POSX=410, /POSY=336).
    As you can see, the menu is not in the same position.
    Mitch, please have a look in the code to see what changed.
    Manny
    the positioning code did change, this is one of the hardest parts to do what we did
    it will have to wait a few days, good thing it only looks like a Y issue
    if i see it ill fix it...
    the problem is all the differen scaling options
    ---------- Post added at 10:38 PM ---------- Previous post was at 10:37 PM ----------
    i prob need this skin, just the popup skin file and its images, would prob do...
    ---------- Post added at 10:39 PM ---------- Previous post was at 10:38 PM ----------
    OR its 100% right, and its a problem with your images, so please attach the popup and its images (.zip)[COLOR="Silver"]
    ---------- Post added at 10:56 PM ---------- Previous post was at 10:39 PM ----------
    ---------- Post added at 11:07 PM ---------- Previous post was at 10:56 PM ----------
    i just tested a normal poup (in elite wings) in 2/1/2011 and 3/1/2011
    the popup popped up in same spot in both...
    has
    /POSX=99
    /POSY=294
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Ok Mi Lord, here is the zip wint the audio player and ratings skin.
      Thanks Mitch
        as i guessed (hehehe)
        you skin file is incorrect... you are scaling the Y size of the form in general.ini
        from your General.ini
        OriginalWidth=800
        OriginalHeight=480
        ShowWidth=800
        ShowHeight=600
        ther fore when you design this skin, all POSX and POSY should be based on the ORIGINAL HEIGHT & WIDTH...
        so, if you set that back to 480 for show height... and do your menu popup, you will see that its OFF
        the correct value in Ratings.skin is:
        /POSX=410
        /POSY=271
        then when you scale the skin, to 600 tall, we scall the POSY to 339 (which to me is the right position, 336, i could still see the bottom of the underneath next, iknow its just 3 pixels)
        btw, thanks for posting the right files that i needed to run though this
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          could have been a bug, that just got fixed
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            i haveing the same sort of issue here ,,,
            if i don't use the /posx values ,, the popup is center of the screen and is fine works well...
            but when i add, the sition values to just move the popup to far left ,, the graphics are screwed up,,
            i have made a popup graphics 400 x 300
            my general.ini is correct as stated above,, 800 x 600 , as my skin is designed in that format
            with position values
            without
            ---------- Post added at 11:49 AM ---------- Previous post was at 11:19 AM ----------
            solved my own issue ,, just made the popup graphics the same size as the skin itself
            but did notice skin editor dose not like the new format ,, you can't move the button box's via mouse
            Riderunner / Genesis
            Wifiman_NET:Version 1.0.0
              there is nothing wrong with /posx, /posy in the menu,popup... i can tell what you are doing from pictures
              nor i do know no anything about new format... new format of what?
              and there is nothing wrong with his general.ini, his /posy was wrong in his ratings.skin
              i wouldnt make the popup the same size of the skin, unless like a dimming effect, like i showed in one of the exit menu examples
              I would use /posX and /posY
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Well, it looks like the redoing of the Genesis skin, is off to a good start...with the correct logo and that song pos bar gfx..
                Next in line: RRMedia v2.0
                DFX 5.1.1 Skin
                Appstore Link
                My RideRunner Plugins
                RRMedia
                RRExtended
                DFXVoice
