Problem DELETEFILE,RENAMEFILE in skin with MENU command
  • Problem DELETEFILE,RENAMEFILE in skin with MENU command
    I have the same problem as liquid_smoke in this thread (http://www.mp3car.com/rr-bug-tracker...u-command.html), I tried the commands Guino offers but without success.
    Do you have another way?
    Thanx
    again, those commands are Directory List required skins
    you provide NO useful information to even begin to help
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      I use directory list in my skin.
      Here a part code of my skin :
      [Buttons]
      B01,7,241,101,54,, <-(Command send by the exectbl via setbuttonid because i use this skin for delete,rename,load,save ...)
      B02,127,241,101,54,"Menu;JumpToLetter.skin",
      B03,247,241,101,54,"CANCEL",
      [Liste]
      IL,DL,RGBFF00FF,RGBFF00FF,***************,0,50,60
      S01,7,7,341,231,128,255,128,000,000,000,255,255,25 5,255,255,255,128,255,128,000,000,000,TRUE,12,"Dig iface"
      Here a part code of my exectbl.ini:
      "MANAGEDEL","MENU;AUDIO_PLAYLISTMANAGE.SKIN||SETPA TH;$PLAYLISTPATH$||SETVAR;VARMANAGE;Effacer||SETBU TTONID;B01;DELBUTTON"
      "MANAGEREN","MENU;AUDIO_PLAYLISTMANAGE.SKIN||SETPA TH;$PLAYLISTPATH$||SETVAR;VARMANAGE;Renommer||SETB UTTONID;B01;RENBUTTON"
      "DELBUTTON","EXIT||DELETEFILE"
      "RENBUTTON","EXIT||RENAMEFILE"
      I hope you have the information needed to help me.
      Thanx
        once you do menu.. the DL has to be on the AUDIO_PLAYLISTMANGE.SKIN
        and no one here can tell what context your in with just snips like that
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Ok, you could find in attachment audio_playlistmanage.skin and exectbl.ini.
          Thanx
            how about the images for this popup
            ---------- Post added at 09:33 AM ---------- Previous post was at 09:27 AM ----------
            also your logic dont make sense to me
            what command do you use to use this skin?
            i dont see how this is going to do anything useful...
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              I use the command MANAGEREN (in the case of renaming) and MANAGEDEL (in the case of a deletion) from exectbl with a button in audio_playlist.skin.
              My logic is to use this skin for several functions (save, load, delete, rename, ...) to avoid the multiplication of similar skins.
              I provided a rar with images and skins.
                ok, FYI delete file only works on DL
                your audio_playlist screen as it should has a PL
                so deleting from the PL isnt allowed, and it would muck up the PL, as technicall you have to remove and item..
                i know what you want to do... but deletefile is ment to come from a DL (directory list)
                not to mention Playlists dont usually have filenames
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  ok, thank you very much for your help.
                  So I will change the command MENU by LOAD and redo my pictures.
                    im not sure that is a solution...
                    there is no solution for your concept, at least right now
                    you CANT use DELETEFILE with a PlayList, only with a DirectoryList
                    m
                    ---------- Post added at 12:38 PM ---------- Previous post was at 12:06 PM ----------
                    that wont work
                    Question, do you really want to have the popup have another PL on it?
                    dont you want to just select the item in audio_playlist.skin, and then press the deletebutton, get a conformation, if you
                    say yes, it deletes?
                    or as in the skin you sent me, you have ANOTHER playlist show up when i go to MANAGEDEL
                    and you pick from that and delete?
                    i need to know...
                    ---------- Post added at 01:16 PM ---------- Previous post was at 12:38 PM ----------
                    i just made delete work for Playlists, i have to do a MINUS1 type code, then delete the file
                    it works...
                    rename isnt going to happen, because thats really tag editing...
                    i suggest, that file management be not done from a PLAYLIST point a view, its just not what Playlists are for
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      When I use the LOAD command instead of MENU that works very well.
                      However it is true that I prefer to use the popup (I find it cleaner visually).
                      But I do not understand, in audio_playlist.skin I use a PlayList but in audio_playlistmanage.skin I use a DirectoryList. So when i go to MANAGEDEL it load the MENU audio_playlistmanage.skin with the DL.
                      I think to understand that the command MENU uses the playlist from audio_playlist.skin because it's the real screen and not the directoryList of audio_playlistmanage.skin.
                      If I use a PL and a DL in audio_playlist.skin I can run but can cause bugs may be?
                        then dont do EXIT||DELETEFILE
                        no menu is same as load
                        once you do EXIT from the MENU, your not on the menu with the DL anymore
                        ---------- Post added at 09:21 AM ---------- Previous post was at 09:20 AM ----------
                        do DELETEFILE||EXIT
                        this closes menu, and DL is gone:
                        now another issue, is the DELETEFILE, opens a popup confirm.skin
                        then that closes, i have no idea, if the menu "audio_playlistmanage.skin" will come back
                        if it dont, then DL is also gone...
                        and it wont work too!
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          the menu "audio_playlistmanage.skin" don't come back after the confirm popup from DELETEFILE.
                          finally I use playlist and directory list on the same screen (see attached image). This work very well.
                          Thanx again for you help and time spent on the problem.
                            ok,looks great!!!!
                            btw
                            i added a DELETEFILE from PlayList in new RR, i cant do a rename, cause thats really Tag Editing!
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
