maximum flash movies inside a skin
  • maximum flash movies inside a skin
    there seems to be a problem in RR regarding the number of flash objects loaded in the skin.
    I am trying to add 4-5 flash swf's in mostly all the .skins in a skin, the thing is that in some .skins the flash won't update, seems like RR is not updating the labels..and/or the swf's appear frozen or won't even appear, it happens like in 2-3 out of 15-20 .skins.. and on a restart it might happen to another .skin, not always the same..
    I have tried changing the swf's with other swf's but that did not help..
    The flash objects are not intensive at all.. they are realy just for displaying some labels indicators etc.
    i tried older RR versions back to January, but all behave the same
    it seems 3 swf's in a .skin is the maximum number without any problems
    keep in my rr doesnt draw or run the flash, thats all handled by adobe... so it could be issue with 1, your .swfs or flash itself
    there is no limit to swfs put in by RR
    and once rr sets the movie name to the object, RR is basically done with it
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      I have seen much the same in one of my skins, too. Not nearly as often on the "non-appearing," but the freezing of RR happens to me about the same regularity as you stated. I assume (there's that danger word) that it has to do with my video driver/memory. Could also be my CPU (1.2G Dual Core), but I don't think so - CPU usually hovers at 54%.
      I have also found that the order that they load makes a difference. Labels that feed flash object need to be early in the .skin. Flash that reads internet info should be last; graphic intensive should be next to last; and ones with the least updates go first.
      I don't know of a limit to the amount if flash RR can handle. I currently have 9 flash objects in this skin:
      As a last ditch effort, you may want to spread them out in the skin file so they don't all load at the same time, i.e., flash/buttons/flash/labels/flash/lists/flash/buttons/flash/images/etc, etc, etc. Lastly, how many plugins are you running and is the flash object dependent on them? That may also have an effect on whether a flash loads.
        I run about 20 swf per skin, mostly without problem...they are small animated buttons/indicators/status swf's....check out my flashflex skin in my sig...
        Sig, smig...
        Ford Flex Toshiba Excite 7.7 Install
        CoverMess - Cool Flash Covers
        FlashFlex - Flash Components for your skinning pleasure
        Mazda Millenia, Road Runner
        YouTube - Road Runner, IGO8 PC, Dashcommand OBD, Visteon HD Radio
          Oh damn! I forgot to mention! Sometime last year Adobe released an update to Flash that totally borked my flash components....try an older veresion of flash, like 12-15 months ago....
          Sig, smig...
            Adobe..Last year...update... I get that nice Flash updater at least once a month or so...one has to keep current when using third party SW, unless you like to find ones creations broken for no apparent reason..
            Next in line: RRMedia v2.0
            DFX 5.1.1 Skin
            Appstore Link
            My RideRunner Plugins
            RRMedia
            RRExtended
            DFXVoice
              there is a possible total flash limit, but I'm still not 100% sure, its about 30 movies, without further testing i cant say for sure
              this isn't a RR limitation, its just a flash activex limitation.. but I'm still not 100% convinced
              and as blue said, i keep updated as adobe pushes them on me, and find no issues, it just gets better with their hw accelleration on h264 videos
              (non rr stuff, but sill important to me)
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                does it mean, i have to downgrade to an ealier adobe flash version and it works?
                RR-Skin: BMW OpenBM Skin for E39 [never ending progress :-(]
                RR-Plugin: IBusCommunicatoRR new Updates
                  dont know, dont think downgrade will help... there just is a limit
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    so i must convert all my buttons to png-file without animation.
                    i asked google a long time. -> no results.
                      or keep the number of flash OBJECTS on a single skin file < say 15
                      then discard the skin
                      /DISCARDABLE
                      If the above is found in a .skin file, RR will unload that skin file once you navigate away from it.
                      This can be useful to keep memory clean and to force reloading of objects of a screen.
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        thank you for this tip.
                        it's difficult to unload the screen, because it needs a moment to load again.
                        but it's a workaround.
                        edit:
                        did a test now and think -> OK. at this time.
