RR 05-01-2011 Release "I must be crazy" + HOTFIX
  • RR 05-01-2011 Release "I must be crazy" + HOTFIX
    I must be crazy release...
    Download HERE
    Download Hotfix .exe attached to the bottom of this post
    fixes issue on "reloadskin" causing splash to reshow when a skin based plugin is used
    (dfx5 users need this)
    HOTFIX is in the installer as of 5/9/2011
    There is so much new in this release...
    I want to thank Dartman_71, who somehow got me to write a new plugin(we'll be releasing soon)
    that got me to tweak up RR a bit
    There is so much new stuff here, the documentation is really lacking. We really could use some help with documentation. Once its started and caught up its easy to maintain, I already have a lot of hours in to RR per week, documentation is always hard for the programmers to do
    Thanks to Gunio for the coding of the new indicators!
    Thanks to anuchit for his excellent testing
    Thanks to whole RR Dev team too...
    Highlights:
    • Indicators now support more than 2 states, images, and can be ontop of buttons
    • Indicators now support "VAR;" so that a actual var contents can be used as an indicator
    • All new foobar2000 Support (v1.1 >)
    • Label; "GPSDATE", "GPSTIME"
    • Skin Command; "CLFIND;xxxx"
    • User Variable; "LISTDESC"
    • 3 New arguments for (SC) Custom List
    • Splash Screen Status label, more detailed to whats being processed
    If anything is broken in this release, just be patient, let us know, and we fix it right away!
    (Resume, and source related stuff.)
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    4/28/2011
    ! Resume rewrite (resume.ini format slightly changed)
    ! Audio Player; Foobar2000, complete rewrite, Foobar2000 v1.1 and greater supported
    + Skin Commands; "VISU;x"  where x = 0,false,1,true. Discrete visual on/off
    + 3 New arguments for (SC) Custom List (OPTIONAL)
      ARGUMENT 21: is options; this argument should be enclosed in quotes and
      each OPTion comma separated, list of options in development
      OPTIONS: "OPT_xxx" - none right now
      ARGUMENT 21: is item clicked; this argument should be enclosed in quotes.
                  This is a standard RR Command string, that should be executed
                  on file select, use this vs a "ONCLCLICK" event in exectbl.ini
                  if this argument is not supplied, or empty, "ONCLCLICK" event
                  will fire.
      example:
      SC01,294,160,400,420,255,255,255,0,0,0,64,64,64,255,255,255,TRUE,20,"Arial Narrow:B",00,"","WEBRADIO_SETURL;$LISTTEXT$;$LISTDESC$",""
      ARGUMENT 22: is item double clicked; this argument should be enclosed in quotes.
                   on file double click select, use this vs a "ONCLDBLCLICK" event in exectbl.ini
                   if this argument is not supplied, or empty, "ONCLDBLCLICK" event
                   will fire.
      example:
      SC01,294,160,400,420,255,255,255,0,0,0,64,64,64,255,255,255,TRUE,20,"Arial Narrow:B",00,"","","WEBRADIO_SETURL;$LISTTEXT$;$LISTDESC$"
      (do nothing on single click)
    4/27/2011
    # Skin Command; "SKIPTODESC" fixed.
    + Skin Command; "CLFIND;xxxx" Will find item xxx in LISTTEXT and set selection on it. (custom lists)
      ex. "CLFIND;myitem"
      note; this is a match on the list TEXT not the DESCRIPTION.
    + New coding for source plugins {WORK IN PROGRESS}
    - removed initial coding for Custom Sources
    + User Variable; "LISTDESC" just like "LISTTEXT" but contains the list item description.
      used like "CLDESC" but no need to setvarbycode.
    4/24/2011
    # Tweak to EXECTBL.ini translation, if translated command starts with "byvarx,ifvar,byindx"
    4/22/2011
    * Splash Screen Status label, more detailed to whats being processed
    + Skin.ini & skins Exectbl.ini logged if not found w/ path tried
    4/21/2011
    + Label; "GPSDATE" returns the GPS UTC Date.  DDMMYY
    + Label; "GPSTIME" returns the GPS UTC Time.  HHMMSS
    4/17/2011
    + Initial coding for Custom Sources {WORK IN PROGRESS}
    + Skin Command; "SETSOURCE;NONE" now will stop: AudPlayer,Radio, XM, & Sirius.
    + Updated skineditor, Italic font property support
    4/14/2011
    + New FoobarRR.dll Player using a completly new method to control foobar2000
      foobar2000 v1.x and greater supported only.
    + Labels now can support Italics, :I or :IB/:BI for bold & italic
    # Tweaked winamp.dll for older winamps < v5.3 for prevention of m3u8 loads.
    4/7/2011
    + Skin Definition; AX Application Window Extended (details soon)
    4/6/2011
    * Updated MPC movie control to open DVD on existing MPC instead of re-running it
    * Added GPS button to Carwings default SIRIUS screen
    + Added "VAR" indicator (Direct Indicator Assignment from variable)
    + Added IMGMask parameter to indicators (Extended Indicator Support)
        I Indicator: IXX,XXX,XXX,XXX,XXX,CODE[,Blinking Rate[,Blinking Off time[,IMGMASK]]]
        IMGMASK can have a mask for files to be used as indicator images.
        ex:
        I01,185,455,30,35,"MUTE:B",500,500,"Test\image_*.png"
        (Displays skinpath\test\image_00.png for OFF and skinpath\test\image_01.png for ON state)
        I01,185,455,30,35,"VAR;MYVAR",500,500,"Test\image_*.png"
        (Displays skinpath\test\image_XX.png for values 00,01,02,etc of $MYVAR$ in 2 digit format)
        NOTE: using VAR; tells RR use to the actuall value in $MYVAR$
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Wow! I was going to download a new release of RR to update my skin when I read this post!
    Now I'll wait for the available download!
    Live today like it is your last day, and behave as though you will live forever...
    my WEBSITE
    MapMonkey Dalai skin-preview-download ITA-email me for ENG
    Road Runner CrystalBlue skin-preview-beta release
      stop adding stuff to RR , and i might catch up lol....
      my biggest issue with the new help file is the skin cmds ,, for the new layout of it ,, it will take a very long time to redo all the cmds ,, i think i have now got a good format that will take the layout mitch would like and others can follow....
      Riderunner / Genesis
      Wifiman_NET:Version 1.0.0
        Certainly a great release !!!!
        Big thanks
          I have been waiting for this version
          I love f2k
          v1 work more power of sound quality and more components
          Thanks Mitch for hard work
            Thanks again Mitch for working with me on the custom audio sources!
            Ryan
              rtgree01, you havent spoke to me since... well... its completly different now
              there is no such thing as "custom sources" anymore...
              they are SOURCES
              if you find me on skype i can go over how to make one...
              also when i got it all finalized, which is really close
              ill document and provide sample
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Does RR support cpu temp monitoring?
                  Several skins have included skins for Speedfan, with which you can easily monitor CPU temp, case temp, voltages, etc.
                    Thanks for this new version.
                    Just one thing, i install just this version and the installer found that my PC is Italian and not French. It's that the first time that the RR installer do that on this PC !
                      no change has been made to the installer...its the same old, same old...
                      could be bug in the installer itself
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        I love this new version !
                        I play just with the new indicators options !
                        I have tried that without success:
                        I,515,2,48,32,"!Traffic:B",500,500,"SKINPATH$Scrip ts\GoogleMapsTools\Icons\Traffic_*.png"
                        This, run very well:
                        I,515,2,48,32,"!Traffic:B",500,500,"Test\Traffic_* .png"
                          yes... indicator image masks, must come from SKINPATH...
                          so
                          "Scripts\GoogleMapsTools\Icons\Traffic_*.png"
                          would be fine
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Dumb question...
                            How do I actully download this? I'm not sure how to navigate this nisu website...
                            Where do I download RoadRunner?
                            2008 Mustang GT CarPC
                              nisuautomative.com -> online shop -> software
                              1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
