Get Ride Runner To Take Up Full Screen
  • Get Ride Runner To Take Up Full Screen
    Hi,
    I'm sure I'm doing something stupid, but I can't get Ride Runner to open full screen.
    It always opens up in the upper left hand corner.
    I've tried changing the resolution of the monitor and the resolution that RR runs at.
    It happens on my 8" touch screen and my 17" test monitor.
    Is there an option I need to check?
    look in your current skin folder , you will find a General.ini file
    open in notepad
    you need to edit the 3rd and 4th line to your current screen resolution, the 1st 2 lines are for what the skin size is
    origanalwidth=800
    origanalhieght=600
    showwidth=1280
    showhieght=1024
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      Thanks!
      I'll try that out tomorrow and see if it works out
        Hi
        Had the same problem, now i ve changed the showwidth/height i can see full size, but RR is offset to the right.
        Can still see first line of desktop icons and lose some of the RR screen ??
          showwidth=xxxx
          showhieght=yyyy
          xxxx and yyyy should match your screen resolution
            Sorta bringing an old thread alive. I recently reformatted my carpc and I notice I get a weird resolution now. Instead of the native 800x480 of my lilliput 8" Now I have to use 720x480. I'm confused why it's so?
