RR 06-01-2011 Release - its already too HOT
This topic is closed.
  • RR 06-01-2011 Release - its already too HOT
    Man, its not even summer and already a few 90+ days
    (and my aircon is on the fritz!!)
    Download HERE
    iList issues should all be fixed, no more is the case of the lost ilists!!
    spent a good day+ working on it and nailed it, with a push by nomader
    (nothing to do with cpu usage)
    lots of bug fixes and tweaks to the new source control code
    even more foobar2k tweaks
    considerable changes in core dvd playback, added considerable DVD support
    for folders playback and .iso mounting
    (REQUIRED MPC-HC build 3158 or greater as DVD PLAYER)
    (for titleset resume, requires mjs build, at the moment)
    Some Highlights:
    • DVD .iso support
    • Skin; 'AUDIO_PLAYLIST.skin" offically supported
    • DVD Play, now supports "DVD_BROWSER.skin"
    • # Detection/Resolution of iList Directx Surface loss issues
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    5/30/2011
    + added option on "LOADLIST" command to not begin play of 1st item "noplay"
    	ex. "LOADLIST;myplaylist.m3u8;MY Playlist;NoPlay"
    5/29/2011
    + Work in progress DVD title set resume (MPC-HC only, mjs build)
    5/28/2011
    + DVD .iso support, removed auto search of DVD Drive from MPC-HC module
    + Setting; "RRDVDDRIVE=x" where x is Physical DVD Drive Letter
      ex. rrDVDDrive=D
    + Settings; for DVD ISO Support
      "RRDVDISO=x" where x is the path to the command line iso mounter .exe
      ex. rrdvdISO=C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe
      "RRDVDISODRIVE=x" where x is the Virtual DVD Drive letter
      ex. rrdvdISODrive=Z
      "RRDVDISOMOUNTCMD=x" where x is the command line arguments to mount the iso
      ex. rrdvdISOMountCMD=/l=Z       (in this case its the LETTER L = Z, where Z is my drive Letter)
      ex. rrdvdISOMountCMD=           (when you only have 1 virtual drive, no need for any arguments, with VCDrive)
      "RRDVDISOMOUNTCMD=x" where x is the command line arguments to un-mount the iso
      ex. rrdvdISOUnMountCMD=/u       (in this case, all drives are unmounted)
    + Events; for DVD ISO Support
      "ONDVDISOMOUNT"           Fired when ISO mounting procedure is requested.
      "ONDVDISOMOUNTCOMPLETE"   Fired when ISO mounting procedure is complete.
      "ONDVDISOMOUNTTIMEOUT"    Fired when ISO mounting procedure has timed out (no DVD VIDEO_TS Structure found)
    5/24/2011
    ! More source control rewrites, removed alot of ELSE drop thoughs
      this will tigthen control of source in rr, and might break some exising
      skins that worked because of the bad drop thoughs... nothing is hard to fixup
    + Skin; 'AUDIO_PLAYLIST.skin" offically supported, will populate DL with
            ".m3u.m3u8" file types from your PLAYLIST PATH
            (no need for a "SD" definition)
    + Skincommand; "PLAYLIST" is alias to "load;audio_playlist.skin"
    5/23/2011
    # Fixed PL refresh for XM & Sirius
    ! DVD Play, now supports "DVD_BROWSER.skin" and playing from DVD IFO Stucture Folders
    + Setting; "RRDVDFOLDERSPATH=path" where path is the path to DVD folders and .iso files
      ex. rrdvdfolderspath=E:\_RideRunnerTestMedia\DVD\
    5/22/2011
    * Tweak, at RR startup of sources (valid at 1st "ONSOURCECHANGE")
    5/20/2011
    # Resume to music tweak, prevention of entering function while in function, due to waiting on winamp for track position/length
    # Radio Modules; Added refresh of PL, which got removed from CORE during source rewrite
    # Audio Player; foobar2000, RR Control Server updated to 1.0.1 (confirm after install)
    # Audio Player; Foobar2000, added wait to allow foobar time to process a large RRPL
    # Audio Player; Foobar2000, added missing version information.
    # Audio Player; Foobar2000, small tweaks to foo_RRControlServer.dll now at v1.0.1 (REQUIRED)
    5/19/2011
    # Detection/Resolution of iList Directx Surface loss issues (Thanks to Nomader, for the push)
    + Skin Command; "EXECFROMFILE;filepath.ext"
      ex. EXECFROMFILE;mycmds.txt
    * CLLOAD files can have description/text with variables to be replaced.
    5/14/2011
    # 2 small issues with foobar player fixed.
    * Cleanup of CheckIn(), related to media sources
    + Setting "PRELOAD=" depreciated, use "PRELOADEDSCREENS="
      Format: skinname1.skin;label1|skinname2.skin;label2   Use | as separator
              label is optional
      ex. PRELOADEDSCREENS=MJSG_USB_IO.skin;USB IO|MJSG_USB_LED.skin;USB LED
          PRELOADEDSCREENS=skinname1.skin;|skinname2.skin;
    + Setting "KEEPLOADED=" depreciated, use "KEEPLOADEDSCREENS="
      Note: Preferred method is /KEEPLOADED in skin definition
      Format: skinname1.skin|skinname2.skin   Use | as separator
    5/13/2011
    # First use of "LASTSCR"
    5/7/2011
    - The old Built-in Voice Control by whodwho in core
    - The above setting for the RRConfig
    # Plugin loading status on the splash when a there is skin loaded plugin, caused
      splash sreen to reappear when issuing a RELOADSKIN cmd and RR to hang
    5/5/2011
    + Audio Players now support UNC Paths inside Playlists
    5/1/2011
    # Custom list txt files with unicode header bytes supported
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Certainly an another great RR version.
    Big thanks for your regular job
      version which I like very much.
        What is the "preferred" or best mp3 player to use now? I've been using Winamp until now but wondering if WMP or Foobar is now a simpler, better way to go. Thanks!
        Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
          hard question to answer... winamp is fine...
          right now, i really like foo, but not because of anything but the control i got over it...
          but as of today has no line in plugin... so if u need that, winamp
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            u still haven't started coding one? :P
              I must say
              On windows
              foobar2000 (sound) better than other player and more power
                I installed this update and somehow everything is wacky in RRConfig. Is there a way to fix this? Gonna revert back to old exe if posaible.
                Bobby
                  The website actually still says May update. June is not released yet. I have been told that RR Config is fixed, so I am hoping it is in the June update.
                  CAR: 2007 G35 Sport Coupe 5AT
                  HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
                    Correct, it is there once the dl becomes avail
                    Next in line: RRMedia v2.0
                    DFX 5.1.1 Skin
                    Appstore Link
                    My RideRunner Plugins
                    RRMedia
                    RRExtended
                    DFXVoice
                      New version is up.
                        Hi Mitch,
                        Thanks a lot for your updates.
                        After installing the 6/1/2011 version of RR, and also installed the latest version of Foobar 1.1.7, my Visualization disappeared. I have some questions to ask....
                        1. RR Control Server V1.0.1, where can I get this?
                        2. Also, the foo_RRControlServer.dll, where can I get this?
                        I've checked my settings in Foobar2K, and everything runs Ok, even the COM Automation Server
                        Global key setting is correct, and the skin is eLite 1.6.6
                        The command to customized audio page is "LOAD;audio_visuals.skin||VISU"
                        Thanks for your help in advance!
                        Thanks in advance!
                          Originally posted by vinchan View Post
                          5/20/2011
                          Hi Mitch,
                          Thanks in advance!
                          Here, http://www.mp3car.com/road-runner/14...yer-notes.html, you have the answers to your questions !
                            The TOGGLEEQ command stop or run very well the foobar equalizer but is not mentioned into the Skins Commands.txt file !
                              Hi Mitch
                              Thanks for your prompt reply. It works!
                              It seems like the Winamp Shpeck Winamp Visualization is no more supported.
                              It's OK for me.
                              One more issue is the Cover art, it does not come out until I go into Audio_brower.skin or any other skin and exit.
                              Again, your prompt help is very much appreciated.
