Firefox
  • Firefox
    I want to use firefox on with my setup instead of IE. I have XP pro running the DFX 5.1 skin. Is it possible to embed firefox, or is IE the only option?
    Josh
    Into RRconfig, in General Settings/Page 3, you can change the Web Browser
      if u want a better browser, use my plugin(auto app mart), but its ONLY IE, cause FF doesnt support third party control
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        K, thanks. I was just trying to stay away from IE, but I guess I'll sacrifice it for functionality.
          So I downloaded the plug-in, but it opens firefox in the carwings lite skin.
            well all i can say give Mitch's pi a go ,, its a great little PI , its much better than the rr web browser function alot smoother and instant .
            Riderunner / Genesis
            Wifiman_NET:Version 1.0.0
              You could also try fennec, which I believe is a more mobile version of Firefox.
              CAR: 2007 G35 Sport Coupe 5AT
              HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
                Yah, that was my next option if I can't get this working.
                  can we assume you installed it?
                  look at debug.txt to make sure its going
                  also.. ie7 >
                  use ie9 it really is the best browser out there
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    also.. ie7 >
                    Yes, I installed it. I havent had much time to mess with it yet. When I get a chance to mess with it I'll report back.
                      So I installed IE 8 and re-installed the plugin, but still no luck. It doesn't even show up in RR. And there's no debug.txt in the plugin folder.
                        what is it?
                        debug.txt will only show in the directory that it should be in...
                        which depends on your setup...
                        legacy = rr root
                        proffile = mydocuments\riderunner\
                        test with carwings!!
                        also.. if someother "web broswer" type plugin is installed, it could take over and not the the plugin you intended too
                        all is known, in debug.txt
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          what is it?
                          legacy = rr root
                          My problem is I can't find the debug.txt. Lol I look in all the directories that pertain to RR and can't find it.
                            1st did you turn on debugging?
                            rr.ini
                            [Debuging]
                            debugmode=true
                            debugfresh=true
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              rr.ini
                              [Debuging]
                              debugmode=true
                              debugfresh=true
                              No, do I need to for the RR.ini to show up? In RR config debugging isn't checked and hide RR.ini is checked.
