Max Speed Attenuation Question
  • Max Speed Attenuation Question
    I was wondering if there was a way to get the GPS-controlled Volume to max out at a certain percentage (below 100%) and stay there once it hits the max speed.
    I have it set up right now as:
    Min Speed: 0 --> Volume: 30%
    Max Speed: 70 --> Volume: 70%
    The problem is that the Max volume seems to just scale with my speed, even past 70mph. If I'm going 85mph, the Volume will go up to ~80%.
    The road noise in my car doesn't really increase that much between 60 and 80mph, so I'd like to be able to have the volume stay at 70% once I get up there. Is there a way to get RR to do this?
    Thanks!
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
    May be, you can use this RR command with the label GPSSPDN:
    Code:
    "IFVAR"		- simple variable compare (equals or not equals only and string contains)
    						ex. "IFVAR;myvar=5;DOTRUE<<DOFALSE"
    						if myvar = 5 then "DOTRUE" would execute, else "DOFALSE"
    						ex. "IFVAR;myvar<>1;DOTRUE<<DOFALSE"
    						if myvar <> 1 then "DOTRUE" would execute, else "DOFALSE"
    						ex. "IFVAR;MYVAR~#;TRUECODE<<FALSECODE"
    						if MYVAR contains a "#" then "TRUECODE" else "FALSECODE"
    IFVAR;GPSSPD=0;SETVOL;Player;30<<SETVOL;Player;70
    But the RRextended plugin can certainly make a better setup.
      That IS the way it is supposed to work. Which of the modes did you set it to? I personally use the linear, but I also have mine setup in a non std way to get it work how I want it to work and works as such.
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        I have it set to Linear, controlling the main volume line.
        I'll recheck it when I get home, but in the 3+ years I've been using RR, it has always gone past the Max volume for me.
          I checked this on the way home today and did find that it just blows right past the max. I could check the code and see why it goes over...
          DFX 5.1.1 Skin
          Appstore Link
          RRMedia
          RRExtended
          DFXVoice
            some settings in RRconfig arnt 100% right for this... that might be related...
            these are the known settings...
            [Native GPS - Speed Controlled Volume]
            SpeedAtt=False
            SpeedAttMute=True
            SpeedAttMaxStep=100
            SpeedAttMode=line
            SpeedAttVolZero=70
            SpeedAttSpeedA=0
            SpeedAttSpeedB=70
            SpeedAttVolA=50
            SpeedAttVolB=100
            SpeedAttGainAt50mph=5
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
              Here's what my rr.ini says under the GPS Volume settings:
              speedatt=true
              speedattmute=true
              speedattunit=mph
              speedattmode=line
              speedattvola=30
              speedattvolb=75
              speedattspeeda=0
              speedattspeedb=75
              speedattmaxstep=10
              I don't see "SpeedAttVolZero" or "SpeedAttGainAt50mph" anywhere. Could that be the problem?
                No, I fixed this & just have to sumit the change, will be in next months update.
                DFX 5.1.1 Skin
                Appstore Link
                RRMedia
                RRExtended
                DFXVoice
