Looking for new xmcache.ini for new channel lineup
  • Looking for new xmcache.ini for new channel lineup
    I need to update my xmcache.ini to the new channel lineup. Can some please point me to the right place. I used to have a progy that dl it off the net but thats not working. Thanks in advance.
    NO, thats not how a cache file works!!!!
    in rr.ini turn off xm cache
    xmusecache=false
    then the next use of RR, it will generate a new cache file, and you optionally can set it back to true
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      I didnt have xmusecache=false in my rr.ini I did add it but didnt help.
      I am running older software. dfx4 . Haven't updated anything for a while since it has been working good.
      So that didnt work. Do you have the xmcache file that you can post?
        you prob have it true!
        set it to false!!!
        run rr, till all the channels come in....
        then exit rr
        set it back to true
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          I set it to false and let it run for a hour. Would it be too much trouble for you to send me the file? I have a broken leg and its a little rough going in and out testing this right now. Just want to get my xm going again. Thanks
            i dont have XM, so i cant send you the file...
            it doesnt take an hour, it takes < 2 mins, < 1 min if you got good singal!!!!
            if its false, it will automatically create the file...
            dont channels show up when you go to xm?
            assuming you have signal strength...
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              I have it set to false. I get preview and a few channels show up and that it. Maybe I need to upgrade everything. Used to be you let it upgrade and then set the xmcache.ini to read only. Like I said I have a broken leg and its tough to work on. Can someone PLEASE post or send me the xmcache.ini damn don't see whats the big deal about the file. Is it top secret? Thanks
                oh no thats not how to use it
                its all auto matic...
                if you are subscribed to the channels it will load them... and save them into the cache file
                i never use it myself...when i did have xm... so i would get a fresh load...
                if the file is read only, thats not gonna work!!!
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  thanks for the info mitchjs. I got all this going a few years ago and haven't updated for a while. Maybe it's time I do. Used to update the xmcache and then change to read only so it wouldn't get corrupt if I remember right. Anyway kinda layed up here so was looking to get xm back up. It will load a few channels but no more than 6 or so. Anyway I might just wipe it and start over. I'm sure there has been some updates in the the past couple of years. Take care.
                    if its not loading more than 6, you got some issues....
                    or you sub is dead, and they one some free bee mode
                    all i can say.. is install newest RR, use carwings to test, and go to xm, u should be able to see it load stations
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      na sub is not dead. With the old xmcache file I got everything but just messed up since they updated on 5/4
                      And no not the latest rr. Prob 2 years old. So maybe I better update that and dfx and start fresh.
                      The problem is it was working so good I didn't want to mess with it.
