transisions not working?
  • transisions not working?
    So i was testing out the different transisions and it appears that some of them just dont work... 15 (shift left) and 16 (shift right) do the exact same thing...
    wondering if anyone else has noticed this?
    Planning: [|||||||||-] 90%
    Purchased: [|||||||||/] 99%
    Installation: [|||||||||-] 90% (when is anyone's project ever REALLY done...)
    i tested 15 and 16, they work as expected, one to the left, one to the right....
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      odd... i was using the 6/1 version, tried using them as commands, skin parameters, in skin tool, etc.....
        6/1 is fine... commands?
        you can use them in skins as;
        /EFFECT=16
        OR
        /EFFECTIN=15
        /EFFECTOUT=16
        or in rr.ini
        transition=
        or
        transitionin=
        transitionout=
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          "EFFECT" - This allows you to dynamically select the effect used when trasitioning FROM the current screen to another.
          Example: "EFFECT;0" (fade) -- check /EFFECT skin parameter above for range of values.
          i tried using /EFFECTIN and /EFFECTOUT in the skin file and it didnt make a difference...
