Cannot get a DVD to play. RR 7/1/11 release
  • Cannot get a DVD to play. RR 7/1/11 release
    I fiddled with this for a while today and have only this left to get everything working.
    I tried downloading the latest MPC and installing it, and I upgraded DirectX to the latest. MPC will play the DVD outside of RR, but I only get a green 4:3 in the screen if I try to play it via carwings.
    Once again, I suspect that rrconfig and rr are not in sync and there is little in the way of a current FAQ on this. Which reminds me, the whole FAQ section here seems a bit out-of-date.
    Where should I look first?
    Action figures sold separately
    MPC?
    lets try not to abbr ok?
    Media Player Classic - Home Cinema version?
    try to edit rr.ini with text editor vs rrconfig.... i
    well in rr.ini for dvd:
    now if you put the MPC-HC.exe OUTSIDE of RR root dir... then u need:
    MPCHCPath=C:\Program Files (x86)\RideRunner\mpc-hc.exe
    then here are some key settings(example on path):
    DVDPlayer=MPCHCVidRR
    RRDVDDrive=D
    RRDVDFoldersPath=E:\_RideRunnerTestMedia\DVD\
    RRDVDBrowse=False
    for iso (example only):
    RRDVDISODrive=Z
    RRDVDISO=C:\Program Files (x86)\Elaborate Bytes\VirtualCloneDrive\VCDMount.exe
    RRDVDISOMountCmd=
    RRDVDISOUnmountCmd=/u
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Here's what the rr.ini says:
      [Video Player Setup]
      videoplayer=MPCHCVidRR
      mpcpath=C:\Program Files\RideRunner\mpc-hc.exe
      [Video]
      videopath=Click here to set path
      videoautohide=true
      videohidetime=4
      videoshuffle=false
      [DVD Player Setup]
      dvdplayer=MPCHCVidRR
      The mpc-hc.exe is in the same folder as riderunner.exe at c:\program files\riderunner\
      What is the RRDVDFoldersPath point to? I have no E:\ drive and my DVD drive is D:\
      With the changes you mention above, when I click on DVD in carwings, I get a Media Player Classic dialog that says :
      Unrecognized switch(es) found in the command line string:
      C:\Program Files\RideRunner\mplayerc.exe /fullscreen /slave 132012
        That looks a bit confusing. This is the rr.ini settings I have when I get the error above:
        mpchcpath=C:\Program Files\RideRunner\mpc-hc.exe
        [Video]
        videoautohide=true
        videohidetime=4
        videoshuffle=false
        [DVD Player Setup]
        RRDVDDrive=D
        RRDVDBrowse=False
          you do have some mixed settings...
          use what exampled, and put in your drive and path settings!!!
          make sure you dont have any duplicated settings...
          since u got both videoplayer and dvdplayer set to MPCHC, you wont run mplayer.exe (hell delete it...)
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            RRDVDFoldersPath is a path if you are going to use NON physical DVDs
            like
            d:\Media\DVDs\
            and in this path you have say
            Spiderman\VIDEO_TS
            blabla...
            or iso
            Spiderman\Spiderman.iso
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              It is not clear to me whether or not the entries in the rr.ini under [Extra's] are used for the DVD playing or not. I added the above commands, but when I ran rrconfig to change something else, it moved the DVD entries to the [Extra's] group.
              So, I moved the entries you supplied as follows:
              [Video]
              ; videopath=Click here to set path
              videoautohide=true
              videohidetime=4
              videoshuffle=false
              [DVD Player Setup]
              RRDVDDrive=F
              RRDVDBrowse=False
              I also deleted mplayer.exe from the RideRunner home directory.
              When I click on the DVD button in carwings, it clears and I get -4:3
              in the upper left but the dvd does not play.
              Note: the RRDVDDrive is correct as F as I checked my dvd drive in My Computer. earlier I stated it was the D: drive and that was incorrect.
                it doesnt matter where in the RR.ini the entries are...
                but you dont want duplicates!
                if you want, attach your rr.ini here (ATTACH) .zip it...
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  Attached is my rr.ini.
                  Let me know what you find.
                  Thanks in advance.
                  john
                    Well, the only thing I found was that the setting "mpchcpath" was set and was said to only set it if your mpc-hc.exe resides outside of RR's root. But that is about the only thing that I found when looking at your rr.ini
                    Next in line: RRMedia v2.0
                    DFX 5.1.1 Skin
                    Appstore Link
                    My RideRunner Plugins
                    RRMedia
                    RRExtended
                    DFXVoice
                      That would be a bug if specifying the correct path to the player causes it to *not* play, wouldn't you say?
                        I'm sure that it doesn't matter as it would more or less just set the setting to the same setting before reading in that setting. But as I noticed, that was the the only thing that I could find....
                        DFX 5.1.1 Skin
                        Appstore Link
                        RRMedia
                        RRExtended
                        DFXVoice
                          other than a few lines with ; infront of it, thats not a comment in an ini file...
                          fix them up...when you get to it....
                          i dont see any reason why dvd wouldnt work, assuming this is right
                          NEWEST RR ONLY
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            you can set mpchcpath= to the path of the mpc-hc.exe no matter where it is
                            its just NOT needed if mpc-hc.exe is in the folder of rr
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              one thing you should see, who NO DVD in the drive, is the MPC-HC logo...when you go to DVD...
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
