Short cables for Sirius SC-C1 and MJS Gadget
  • Short cables for Sirius SC-C1 and MJS Gadget
    Anyone know where I can get a short (2"-6") version of the DIN cable that goes between the SC-C1 and the MJS gadget? Actually a rigid male-male connector would work.
    I'd go on my own search but I not sure what to call it and how many pins it has.
    Also, is there a chassis mounted socket available for the SC-C1 antenna?
    I'm installing all my components in a chassis and can find most of what I need but I can't find the short DIN cable/rigid connector and a chassis antenna mount.
    Regards,
    Jim
    Good luck with that.
    In the words of Mitch at MJS.. "Adapt!"
      you would have to make your own cable, and its not that simple, the audio lines inside it are shielded
      but for a short cable... it might be ok....
      i would pin it out... its prob straight...but confirm it
      you only have to do 6 pins, 7 & 8 not used (if memory serves)
      as for antenna... isnt sirius antenna connectors just SMB, i think so
      many options there
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        Well you made the thing
          i didnt make the cable, sirius did...
          i just know what pin does what... not anything more
          (other than its construction, cause i opened one up)
          but this is 3 years ago...
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            I'm all set. I found an outfit online that makes 6" 8-pin cables. They also make other pre-made cables. I alos found SMB to F-type connectors so I can use coax for the antenna connections inside my component box.
            The reason for the component box is that I am using a Fujitsu Lifebook that was laying around as the computer and display head.
            Regards,
            Jim
              Regards,
              Jim
              Would you mind sharing where you found it?
              I'm still not sure if the SC-SC-USB adapter will even fit in my car, but a shorter cable might help.
                CablesOnDemand.com
                Parts No.
                CS-DNPDM8MMX2-001 "CBL MD8 MALE/ MD8 MALE 1'"
                Regards,
                Jim
