icon transparency in list
  • icon transparency in list
    I have problem with transparent icons in lists
    if I use that line (as CARWINGS lite) no problem the icon is transparent :
    IL,DL,transparent.bmp,sel.bmp,,0,50,60
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,20,"Arial"
    (cf image 2)
    if I change the font, the icon is not transparent.
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,20,"Digiface"
    (cf image 1)
    Also if I change the font size
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,22,"Arial"
    (cf image3)
    one would have a solution?
    You seem to be having some issue I'm not seeing here...
    This worked fine here (Just copied/pasted your line) -- got transparency as it should:
    I also tried this and it again worked fine (Different font and size, below screenshot):
    S,140,85,519,439,0,0,0,0,0,0,255,255,255,255,255,2 55,128,128,128,0,0,0,true,30,"Ericsson GA628"
    I can only assume this issue may have to do with the DirectX version and/or video card driver -- I assume those are all iLists ?
    Ride Runner RR's Myspace
      Yes I use Ilist.
      I downloaded the lastest drivers for the graphic card and directx but I still have the same problem.
      I specify that this happens on XP with seven I do not have this problem.
      Thank you
