RR 09-01-2011 Release
  • RR 09-01-2011 Release
    wow is the summer over or what?
    Download Here: www.nisuautomotive.com
    Not much new in this release, mostly small issue fixes...
    The NEW RRConfig is in this release as 1.0.0.0
    we are continuing to work on it, cleaning up the plugin support
    and will also look to add tool tips
    *** JUST a Note to all you DFX5 users, you need to follow the link below for the fix opts . Not optional from this RR release forward!DFX 5.1.1 QnA Post#2
    Got a bunch of Plugins to post:
    Download them here: https://skydrive.live.com/?cid=ED932...BF9C9CB3%21313
    • New GPS2City plugin - basicaly its the code that was in the core of RR
      to take GPS Cordinates and locate what city you in (USA Only)
    • Updated IE WebBrowser plugin
    • Updated MJS Gadgets UAS4 Plugin (addes the RRConfig Plugin)
    Thanks to RTGreen for wonderful work RRConfig, getting it from idea to something usable.
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    9/1/2011
    ! New RRConfig included in this installer, *required .net 3.5sp1
    + Skin Indicator; "FOLDERART" shows the folder image file(based on coverart setting) of the currently playing file (Audio must be active)
                      if no file present, it will look for "NoFolderArt.jpg" in skin path
    + Skin label;     "FOLDERART" is same as indicator (textual path)
    8/24/2011
    * Volume Table file, is NOW named "VolTBL.ini"
    8/16/2011
    ! Exectbl.ini processing - now allows ONxx or *ONxxx events to fire in both
      global or skin tables
    8/15/2011
    # Fixed "QUIT" to allow "ONEXIT" event to fire
    8/14/2011
    + "w_xday_dayname" labels to the weather plugin, shows day only Sunday/Monday/ect...
    8/9/2011
    # Setting; "audiorepeat", "audioshuffle", & "videoshuffle" fixed parsing of "true"
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Cool,
    I can't wait :-)
      Is the new command FOLDERART compatible with the MediaArt plugin?
        mediaArt plugin doesnt have a folderart indicator... so
        the plugin doesnt touch FOLDERART
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          hi mitch,
          thanks for changing the mediaart plug and the rr install in part of AlbumArt, MediaArt and FolderArt.
          if i can take the MediaArt picture behind the browserlist i will be the happiest user.
          regards
            Originally posted by Enforcer View Post
            Nice looking skin there GF-ler
            thanks for it.
            my biggest wish is, to bring the MediaArt Picture behind the browserlist.
            donīt no if its possible for RR.
            i saw it once in the FSR skin.
            regards
              Wow, a whole lbl dedicated for TnA
              Looks nice otherwise...
              Next in line: RRMedia v2.0
              DFX 5.1.1 Skin
              Appstore Link
              My RideRunner Plugins
              RRMedia
              RRExtended
              DFXVoice
                cmd issue in exectbl.ini
                for some reason this cmd works in a skin file but not from exectbl.ini,,
                SETVARBYCODE;flashgame;CLDESC||savetoskin;Flash;$F lashgame$
                the 1st part is ok ,, but it won't savetoskin , but in skin tool or a skin file it saves no problem
                **EDIT**
                this is useing the Daily rr.exe downloaded today ver 22/09/2011
                and using skin exectbl.ini
                Riderunner / Genesis
                Wifiman_NET:Version 1.0.0
                  thats too abstract for me to evaulate...
                  how about the exact line in exectbl.ini
                  and did you look at debug.txt to see what its doing
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    Hi Mitch, I couldn't get the following to work
                    8/14/2011
                    I checked the date of the Weather.dll file in the plugin folder and it's dated 6 July 2011. This is installed with the Sep release. Not sure if it was an old version that was bundled wrongly...
                      Oh yes Mitch, there's another bug which I have been trying to report. In my video player skin, I have a button "HIDECONTROLS" which allows me to watch the video fullscreen. It stopped working on my CarPC since the last few version. But when I test it back home on my office laptop it is working as it's suppose to. Finally I found the problem. I reduced the resolution of my office laptop to 800x600 to match my CarPC and true enough the HIDECONTROLS button didn't work after that.
                      Hopefully that gives you a clue as to where to troubleshoot.
                        8/14/2011
                        This was added to the old weather plugin, but the installer was never updated with it b/c there was a newer .Net weather plugin that is going to replace it, which does have that Lbl in it.
                        DFX 5.1.1 Skin
                        Appstore Link
                        RRMedia
                        RRExtended
                        DFXVoice
                          Ok, I thought it's already included since it's mentioned in the version history.
                            Seriously, is there any change for an RR auto-updater? Having to trot off to that other website, log in, add to cart etc seriously takes some of the shine off of this project.
                            Live mp3Car Facebook Chat
