How to read the value of a slider
  • How to read the value of a slider
    Hello,
    I need a little help with the slider as GPSSIGNAL .
    I should to read the value of the GPSSIGNAL into an autoit script .
    So, i have tried that without succes:
    Code:
    $myvar = $rr.getinfo("GPSSIGNAL")
    and that without succes :
    Code:
    $myvar = $rr.getuservar("GPSSIGNAL")
    What would be the good way to read this value and put it into a variable ?
    Great thanks
    I am working to figure out why that I cant get a slider code now from RR.... but in the mean time, it may just be far easier anyways to use the GPSSAT label to work with:
    Code:
    $rr = ObjCreate("RideRunner.sdk")
    $RRGPSSignall = $rr.getinfo("gpssat")
    MsgBox(0, '', $RRGPSSignall)
    This will give you a number from 0 to 12 depending on how many satellites you are acquiring.
    If you read the raw slider value, it would give you a number from 0 to 65236 that you would have to decipher.
    My Fiero Build Thread
      The correct way is...
      Code:
      $myvar = $rr.getinfo("SLD;GPSSIGNAL")
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        Code:
        Thanks BlueZX3 and John :-)
