No audio in winamp, everything else ok
  • No audio in winamp, everything else ok
    I have no output from the music player, but I have audio from everything else. HDRadio, nav, weather, CNNnews, video even has audio. I'm stumped. Attached is a debug.
    assuming winamp is set up right, ie right soundcard...
    winamp volume!
    dont hide the player! so u can see
    or use carwings, mixer screen, and raise player volume
    thats my 1st guess
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      I tried that this morning. No dice. I even uninstalled Winamp and tried the other players, thinking that it was winamp. Still nothing. I was thinking it was something in RR muted the player and then didn't unmute it and it was stuck.
      I'm considering dumping the Andrea and just using the onboard audio only for other reasons, but I did check and winamp is set for Direct Sound output and the Andrea is selected..... Weird that every other sound output works but the player.....
        the player is direct, did u unhide the player so u can mess with it...
        when u get the player working it will work...
        you would be able to see if the player is muted!
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          I did unhide and even tried it without RR running and no sound. I switched the config to use Windows Media player and I have sound, and glitchy visualiations again. Thanks for the help (and the coding of RR) Mitch. I'll keep looking at Winamp to see why it doesn't want to make any sounds....
            in winamp, using a modern OS (NOT XP) i use Maiko's WASAPI output
            but wav or directsound should work fine...
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              I've had this problem on two different systems. First time I had this problem I switched from DirectSound to WaveOut. Second time I turned off volume control in the directsound plugin. Both are unrelated to riderunner and need to be fixed inside of winamp.
                I removed the Andrea USB and it's software and went out from the onboard soundcard and now everything (encluding most of my PS noise, engine noise and SSD HD noise) is gone!!!
                I don't know if I got a bad Andrea (it was used from a member here) or what, but it was junk in the CarPC.
