garmin pc support
  • garmin pc support
    I'm thinking of changing over to ride runner from centrafuse
    I've seen that there are skins for garmin - supported by DFX skin
    Just wondering if RR support the mute function when garmin speaks (naviagtion directions)
    Can;t find any info on
    thanks
    You must to patch your garmin with these files (please make a backup of your Que.exe file)
    and use thes commands:
    Code:
    /Option mute when the gps speak
    "NAVPAUSE","SETVOL;Winamp;50"
    "NAVRESUME","SETVOL;WINAMP;255"
    /Used only with RRextended
    /"NAVPAUSE","RRVolRamper_Dn;75;30;Wave"
    /"NAVRESUME","RRVolRamper_Up;100;30
      Code:
      My hero!!! I asked this very same question, a while back. I must have worded it wrong cos never found what I was looking for thank you!!
        If i can help ! :-)
          i assume this patch works for all versions of GMPC. I'm not really sure of i have .60 or .70
          Live mp3Car Facebook Chat
            Code:
              Sorry to raise this old thread but this seems to be the functionality I've been searching for,
              but I have to ask how do I actually use these patch files.
              Do I just paste them into the GMPC folder and register both the .dll files
              Then enter the vol control lines in the rr.ini file
              any help would be gratefully received
              cheers
              jel
                this is not a "perfect" solution...
                the patch part is prob ok, but the exectbl code isnt
                might be wiser with
                "NAVPAUSE", "PAUSE"
                "NAVPLAY","PLAY"
                lowering winamp volume not going to help when listening to radio or sirius...
                (unless of course using line in plugin for all external audio)
                for sure a attenuated audio would be perfect
                but since RR only loosly manages audio... i see no "perfect" way
                -Thanks
                Mitch
                www.rush2112.net
                Sun, Come shine my way
                Wind, Carry me home
                The piece of me that died
                Will return To live again
                  does anyone have a link to Garmin Moble PC.
                  thanX
                    I found it at Garmin's website , just navigate to their support and downloads section. This is the update file to version 5.00.70. But if you use winzip or winrar to open the file you can get to the main installer rather than just straight into the update installer.
                      Garmin GMPC was discontinued a year or so back. I still use it and love it but finding a copy now to buy may be tricky.
                        yeah well that's what are for
                          cheers
                          jel
                          You don't need to register the dll s, .
                          When you patch the que.exe file, a backup is created .
                          The patch create two events, NAVPAUSE and NAVRESUME.
                          This patch run also for Sygic,Destinator,AutoMapa, etc...
                            Code:
                            excuse me, garmin with that?
                            the files in your zip file in that folder should be included?
                            thank you
                              does not work .. I get this error ..
                              "unknown commandline parameter: /runcmd=CURRENT VOL"
                              "unknown commandline parameter: /runcmd=ATT"
