ONRESTORED Carwings_Dynamic_Lite
  • ONRESTORED Carwings_Dynamic_Lite
    When I launch RR with the skin Carwings_Dynamic_Lite, I saw in the debug.txt the command ONRESTORED and a lot of SETVAR like this:
    Executing: ONRESTORED
    Que Exec: Vrai, menu.skin, SETVAR;SKINORIGWIDTH;800||SETVAR;SKINORIGHEIGHT;60 0||SETVAR;SKINSHOWWIDTH;800||SETVAR;SKINSHOWHEIGHT ;600||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION ;0", Faux
    Executing: SETVAR;SKINORIGWIDTH;800
    Que Exec: Vrai, menu.skin, "SETVAR;SKINORIGHEIGHT;600||SETVAR;SKINSHOWWIDTH;8 00||SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITIO N;0||SETVAR;SKINYPOSITION;0", Faux
    Executing: SETVAR;SKINORIGHEIGHT;600
    Que Exec: Vrai, menu.skin, "SETVAR;SKINSHOWWIDTH;800||SETVAR;SKINSHOWHEIGHT;6 00||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0 ", Faux
    Executing: SETVAR;SKINSHOWWIDTH;800
    Que Exec: Vrai, menu.skin, "SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITION;0 ||SETVAR;SKINYPOSITION;0", Faux
    Executing: SETVAR;SKINSHOWHEIGHT;600
    Que Exec: Vrai, menu.skin, "SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION; 0", Faux
    Executing: SETVAR;SKINXPOSITION;0
    Que Exec: Vrai, menu.skin, "SETVAR;SKINYPOSITION;0", Faux
    Executing: SETVAR;SKINYPOSITION;0
    Que Exec: Vrai, menu.skin, "ONSTART", Faux
    So if I launch my skin I don't have these commands SETVAR, I've ONRESTORED and ONSTART.
    Where are these commands in the skin Carwings, I look in exectbl.ini but I don't saw nothing.
    ONRESTORED should only be executed when restored from a minimized state.
    It's possible there is a plugin that is sending those commands when it gets the ONRESTORED command.
      do you have rrextended plugin install that looks like thats where this is comming from
      Riderunner / Genesis
      Wifiman_NET:Version 1.0.0
        Yes I use RRextended but in this case there should be these commands regardless of the skin used
          this could be true, but i know most functions in rrextended are switchable , so its possiable this section is switched on in 1 skin but not another.
          i actually have rrextended here so i tested to be sure , and sure enough it is rrext.
          theres a setting for rr.ini or skin.ini to switch this section on/off
          rrskingen_enabled= (True/false)
            Carputer1 you're too strong, you put your finger exactly on the right variable.
            Thank you very much for your help.
              lol no problems glad to help
                thats not the case , you'll find its fired on rr start up as well... i have seen it fired at different times ,, and not just on restore from minamize
                  Yes, it does fire at startup as is part of the window initz proceedure... its just like the window resize funct gets called before a window is actually shown for the first time....FYI.
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
