new to ride runner
  • new to ride runner
    Ive got a new build finally finished and have downloaded riderunner but i dont know how to configure it or set the skins ive looked in the threads im probly over looking it but is there another program i need to attach the skins if someone could just point me to the right post or thread i would be very greatful
    08 toyota tundra crewmax
    Asus e35m1-i deluxe motherboard w/ process builtin
    8 gb of g skill ripjaw ram
    750gb seagate 2.5 hdd primary
    320gb wd 2.5 hdd secondary
    80gb wd portable for tranfer
    motherboard also has wifi/bluetooth 3.0 builtin
    directed hd radio interface w/mitch's usb cable
    m4-atx psu
    just the cheapest black case i could find
    and using 9 conductor wire to hook up my speakers to the amp that is controlled by my carpc
    but none of it matters if i cant get ride runner to run right with the alpine skin i want
    1st off welcome to RR your journey has only just begun.
    when you installed RR you hopefully see 4 icons on your desktop , if not deselected when running the installer.
    RR / Skin Editor / Skin tool / RRconfig
    for now rrconfig is the app you want , this holds all the settings needed to run RR .
    depending on your OS, depends on how things are placed on your system
    if in profiles mode you will find the skin folder in MY Docs/RR/Skins
    in Legacy mode Programfiles/RR/skins
    as you have picked alpine skin , which is a very old s, so you may or may not find things working correctly with the lastest RR
    just drop the alphine skin folder into the rr skins folder , go through rrconfig , ,,
    if still stuck we are all here to help
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
      I always did like the alpine skins, ran it for quite awhile, would be awesome to see an updated version of that skin...
      Next in line: RRMedia v2.0
      DFX 5.1.1 Skin
      Appstore Link
      My RideRunner Plugins
      RRMedia
      RRExtended
      DFXVoice
        Ride runner newbie
        Sorry I didn't put the os it is windows xp 64 bit
          thank for the info but now im running into a new problem i open rrconfig and get the error : Duplicate ini variable found: visuname=!Winamp gen!AVS anybody have a clue is will not let me configure rr
            good luck running with XP 64, its nothing like vista64 or win7 64...
            would NOT recomend xp 64bit!
            as for the the dupe. how is it NOT letting you configure?
            i made a dupe in my rr.ini, it tells me, and i click OK
            and move on, and edit away.. save and go
            -Thanks
            Mitch
            www.rush2112.net
            Sun, Come shine my way
            Wind, Carry me home
            The piece of me that died
            Will return To live again
              not to mention, how did you even dupe a setting?
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Not really sure how I duped it cause it was the first time I have ever opened reconfig
                  working on getting windows 7 but had a copy of xp64 so i figured i would try it first plus i know my way around xp better than the others
                    admit i did see something like that when i ran the rrconfig for the 1st time on a w7 32 OS Fresh install , got a window popiup saying the same thing ,,
                    but i agreed with mitch on the OS , i have heard a few users useing 64 bit OS , from xp - w7 ,, all gave issues in one way or another ,,,
                      sheeze no one mentions anything anymore!
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        i know what your like ,, so wanted to verifie 1st ,,, make sure i was 100% , but as this was mentioned in this thread before i had chance ,
                        only found it myself last night .....
                          i just ran rrconfig on the rr.ini supplied as base one
                          prob could use some tweaks
                          it will be in next installer
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            did a clean reinstall of ride runner and now i can configure dont know what have done different but i works now thanks guys for the help i will keep on posting my progress and updates
