RR 10-01-2011 Release - Something Wicked This Way Comes
  • RR 10-01-2011 Release - Something Wicked This Way Comes
    Ok, its RED-OCTOBER here!
    Download Here: www.nisuautomotive.com
    A couple of small fixes, a few new little things
    and one new big thing
    We gonna save the big thing for another post, we have much to complete (mostly some documentation)
    Highlights:
    • Media List, Ilist enhancement (the big new thing)
    • Skin Command; "RRSaveToCustomINI" save information to a ini file
    • Uservar; "RRMIXERLINELIST" contains a list of available mixer lines, ";" seperated
    Media List is offically Beta, untill it proves it self out...
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    10/1/2011
    + Media List Code BETA (See new MediaList.txt)
    + Skin Definition; "ML,PL,<format>[,ParabolicWidth]" (See new MediaList.txt)
    9/25/2011
    # Issue if ID3 Tag has a zero length tag
    + "ONCLPOSCHANGE" event is raised for CustomLists
    + Uservar; "RRMIXERLINELIST" contains a list of available mixer lines, ";" seperated
    + Skin Command; "RRSaveToCustomINI" save information to a ini file
      "savetoini;<path+file>;<setting>;<value>"
      example: "rrsavetocustomini;$SKINPATH$myfile.ini;setting;true
      this will write to myfile.ini (in skin path) setting=true
    9/24/2011
    + Skin command; "RRGetOption"    (details soon)
    + Skin Command; "RRSetOption"    (details soon)
    + Skin Command; "RRGetPath"       (details soon)
    + Skin Command; "RRGetFile"         (details soon)
    9/21/2011
    # Fixed issue with a possiblity of an empty global exectbl
    9/6/2011
    # Fixed, media.gif and folder.gif save outs, when they dont exist, they now save as true gif files
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Introducing MediaLists (enhanced iList)
    these are 100% configurable
    its going to look very confusing, we are working on an application to assist
    examples...
    http://img692.imageshack.us/slidesho...d=unledqfz.jpg
    Code:
    /, (ML) Media List Properties -- (May be Extended later)
    /, LIST FORMAT PW
    ML,LIST,FORMAT[,PW]
    This Optional definition expands an iList to form a MediaList. A Medialist can have custom size, text position,
    fonts and Icon position/sizes.
    LIST defines which list is being defined - can be PL or DL currently (May be expanded later)
    FORMAT is the format desired for EACH ITEM in the MeduaList (See Format Notes below)
    PW is the Parabolic Width for the list. 0 (Zero) means it is a straight iList (Standard). A Positive value will
       cause the list to have a "curve" effect from poxision X=0 at the top to position X=PW at the middle back to
       position X=0 at the bottom. A Negative Value will cause the list to have a "curve" effect from position X=PW
       at the top, to position X=0 at the middle then back to X=PW at the bottom.
    Parameters Available for FORMAT field (Note that each parameter set is persistent until the end of EACH ITEM):
    %ItemH=H% - H is the height for each list item. Without this parameter, the Height will be automatically set.
    %IconX=X% - X is the X position for the Icon in each Item. Default is 2.
    %IconY=Y% - Y is the Y position for the Icon in each Item. Default is 2.
    %IconH=H% - H is the height the Icon in each Item. Default is the same as the default Font Height of the list.
    %IconW=W% - W is the width the Icon in each Item. Default is the same as the default Font Height of the list.
    %TextX=X% - X is the X position for the following Text in each Item. Default is IconX+IconW+2.
                A negative X value indicates X pixels from the right edge of the list.
    %TextY=Y% - Y is the Y position for the following Text in each Item. Default is IconY.
    %TextW=W% - W is the maximun width for the following Text in each Item. Default is the ListWidth-TextX.
    %Color=C% - C is the color of the text, in the format RRGGBB or #RRGGBB. Default=color from list definition.
    %SColo=C% - C is the color of the SELECTED text, in the format RRGGBB or #RRGGBB. Default=color from list def.
    %Font=FONTNAME:SIZE[:B]% - Sets the font for the following text. Default is the font defined for the list.
    Tags availabe for FORMAT field:
    %list#%
    %title%
    %artist%
    %album%
    %genre%
    %year%
    %tracknumber%
    Examples:
    ML,PL,"%ItemH=50%%TITLE%%TextY=30%%Font=Arial:12:B%%ARTIST% - %ALBUM%"
    ML,PL,"%ItemH=50%%Font=Arial:18:B%%TITLE%%TextY=30%%Font=Arial:12:B%%ARTIST% - %ALBUM%"
    ML,PL,"%SColr=#00B800%%Color=#FFFFFF%%TextW=400%%TITLE%%TextY=28%%Font=Arial:12:B%%Color=#819FF7%%TextW=350%%ARTIST% - %ALBUM%%Color=#009933%%TextX=-90%(%YEAR%)",45
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
      reserved #2
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        Cool, miam, a love the first days of each month !
          Code:
          ML,PL,"%TextY=2%%TextX=2%%list#%%title%%TextY=30%%color=ff0000%%scolr=ff0000%%Artist%%color=808080%%scolr=808080%%TextX=-100%%TextY=40%%font=Visitor TT2 BRK:14:B%%Year%",40
          Code:
          ML,DL,,40
          Ride Runner RR's Myspace
            Well, that really is something new, great job!
              It's a very nice job and very easy to use.
              Greats thanks for tis new version :-)
                i cant imagine how difficult it is to follow the skinning code for these new lists, considering i dont understand CL lol. Definitely something i've been looking forward to though.
                EDIT
                ok, its not too bad i guess, but i already have a question. How can we implement variables for the color codes aka"
                %SColr=##FONTTHEMER##FONTTHEMEG##FONTTHEMEB#% doesn't work.
                EDIT
                nevermind removing the color definition uses the default list color.
                EDIT AGAIN
                two more question for now.. is it possible to provide alignment directives for each portion of the list. For example in a like with 0 as the PW, can we right align the %YEAR% portion of the list? Also, my font appears distorted in this type of list. anything i can do to fix that or will this list have problems with truetype fonts?
                Live mp3Car Facebook Chat
                  i was wondering ,,, i know this is 1st draft of this code ,, but will be added to cl func
                  Riderunner / Genesis
                  Wifiman_NET:Version 1.0.0
                    Sonic: If you use transparent iLists, then anti-aliasing (font smoothing) is disabled as it has always been. If you use non-transparent iLists, you should be able to have full font quality. You should be able to use /DEFINE for colors but I would suggest not using the # on the format (it's optional) to avoid confusion.
                    Carputer: We can add it to CL, we're just trying to think of HOW it could be used.
                      patiently waiting ....
                      BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
                      RRTube ==> [View/Download Youtube Videos]
                      WifiMan ==> [Wifi Manager]
                      RRec ==> [Audio Capture]
                      If You Want To Be Given Everything, Give Everything Up ...
                      Bird York -- In The Deep --
                        sonic, this has NOTHING to do with CLs, and was a bit of work as it is now...
                        its new and not that hard to use and position text, once you look at it a bit...
                        a little patience, and we are working on a Media List Builder GUI Application
                        its primarally driven by ID3 tags...
                        and try a TEXT MODE IL they really nice and smooth
                        pop this in carwings Audio_player.skin
                        Code:
                        IL,PL,RGBFF00FF,RGBFFFFFF,,2,50,80
                        ML,PL,"%SColr=#00B800%%Font=Trebuchet MS:18:B%%Color=#FFFFFF%%TextW=470%%TITLE%%TextY=28%%Font=Trebuchet MS:12:B%%Color=#819FF7%%TextW=420%%ARTIST% - %ALBUM%%Color=#009933%%TextX=-50%(%YEAR%)"
                        S,120,80,474,454, 255,255,255, 255,255,255, 255,255,255, 0,0,0, 0,0,0,false,18,"Arial:B"
                        you can see year is right aligned
                        Uploaded with ImageShack.us
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          THIS IS GREAT.. in fact i have been dreaming of this since a long long time!!!
                          1 question though that has been driving me crazy many years of RR ing
                          Code:
                            S01,208,144,520,336,0,255,0,000,000,000,255,0,0,0,255,0,0,0,0,,34,"Century Gothic"
                          why the heck isn't it possible to have a different color for the PLAYED ITEM???
                          the bold 255 above should make the played song red...but it does not
                            nomader, i assume your question is unrelated to ML
                            if you want to report it as a bug, thats one thing, but if its been years, then you are already crazy
                            -Thanks
                            Mitch
                            www.rush2112.net
                            Wind, Carry me home
                              come on... i started my post by saying "THIS IS GREAT", just to avoid being naged :P
                              Good work by the way.. i assume this took many lines of code
