including a button for record
  • including a button for record
    hi, i'm using the webradio plugin and fitted it to my needs to use it with elite 2 skin. is there a simple way to record web streams as in centrafuse? i would like to include a button for this! thx in advance.
    Fruch,
    The eLite 2 private beta includes the ability to record webradio, radio, or sat radio, however it uses the plugin from EL CAMINO, RRec [Audio Capture]. As far as I know, this is the only way this will be possible for now. If you set your recording device default to "Stereo Mix" or "What I Hear", you should be able to record any audio, web-stream audio that your computer plays back.
    My Skins: eLite Lite || eLite Streamline || eLite Wings
      thank you. i'm awaiting the new elite 2 beta like nothing else, but i want to extend the functions of rrwebradio plugin. you said, you're using RRec, but last state is that it isn't working with win 7. does yours work? and how have you get it to work?
      and please let me know if you changed the file "Top-Round.elite" compared to the alpha release. further it would be good to know if we can use the files in elite/menu folder from the alpha release in the new beta.
        Well,...... I asked for this option awhile back about adding a record button to a certain skin which I won't mention. It's called "Stream Ripper" plug/add-on for Winamp. Here is the link -----> http://streamripper.sourceforge.net/ It's free, works excellent and I still use this to date. This automatically loads up when winamp is loaded, which RR uses anyway. The only problem is it's small buttons and you have to minimize RR to get to the streaming window to turn record on/off. Yes,... this would be nice to add this for all RR skins. good luck.
          thank you for the hint. as you said it's not the cleanest solution! i'm prefering a command to use it in all skins, too.
          i would like to embed the function in my modified radio skin of elite 2:
            not trying to hijack this thread, ( just a little ) but BASS player PI, does this with a simple command, and has a WebRadio built in.
            BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
            RRTube ==> [View/Download Youtube Videos]
            WifiMan ==> [Wifi Manager]
            RRec ==> [Audio Capture]
            If You Want To Be Given Everything, Give Everything Up ...
            Bird York -- In The Deep --
              yeah, i visited the BASSRR thread before, and it has really awesome features. but i'm a winamp fanboy maybe i'll have a look at it when i install newest RR release.
                i don't want to start a new thread, since the topic is similar:
                how can i create a button like --> once pressed --> command1 ---> twice pressed --> command2? if it's not clear what i mean: i want to realize a record button for dvbviewer plugin which starts recording on first press and on second press it should stop recording. i don't want to make separate buttons - i need the space for other buttons. is there any tutorial or short explanation? thx
                  SET a variable with the SETVAR command, then use the BYVAR command attached to that variable to create a toggle button.
                  Something like SETVAR;RECORDVAR;0 in ONSKINSTART on exectbl.ini, then your button command would be:
                  Code:
                  BYVAR;RECORDVAR;RECORDCOMMAND||SETVAR;RECORDVAR;1<<STOPCOMMAND||SETVAR;RECORDVAR;0
                  no spaces in the command
                  Live mp3Car Facebook Chat
                    thx mate. is it also possible to load another img to change the button when it's recording? i really have to learn more about variables
