HELP rrconfig wont open...unhandled exception error **Solved**
  • HELP rrconfig wont open...unhandled exception error **Solved**
    Can anyone help me....
    I have just loaded a nlited version of xp pro on my computer loaded all the drivers i needed and everything computer wise is running fine...
    I downloaded and installed ride runner and all installed correctly, i installed .net framework 2 and 4 and vb runtime files... also have XP service pack 3 installed
    however when i attempt to start RRconfig i run into problems... i get this error message...
    Microsoft .net framework
    unhandled exception has occurred in your application. If you click continue the application will ignore and attempt to continue. If you click quit the application will close...
    Could not load file or assembly 'system.core Version+3.5.0.0, culture=neutral, publickeytoken=b77a5c561934e089' or one of its dependencies. the system cannot find the file specified
    and in the details section...
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.FileNotFoundException: Could not load file or assembly 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. The system cannot find the file specified.
    File name: 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
    at RRConfig.nodeGeneralPage1..ctor(ResourceManager r)
    at RRConfig.MainForm.MainForm_Load(Object sender, EventArgs e)
    at System.Windows.Forms.Form.OnLoad(EventArgs e)
    at System.Windows.Forms.Form.OnCreateControl()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
    at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
    at System.Windows.Forms.Form.WmShowWindow(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at RRConfig.MainForm.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure logging.
    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    RRConfig
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/RideRunner/RRConfig.exe
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Can anyone unriddle this for me, or has anyone come across this...
    Thanks Heaps,
    Tom
    Problem solved... installed .netframework 3.5 :s cant understand why version 4 didnt work but ohwell...
      Each version of the .Net framework is independent. An app written for .Net framework 3 will use that version of the framework on your PC, regardless of higher versions. So, even though you have .Net framework 4, it's still good to install the service packs for 2.0, 3.0, 3.5, etc.
        To which is odd, I thought the same, awhile ago when i only installed ver 4, thinking it would cover the installed n backwards...don't exactly understand why they did it like that... you certainly don't have to install SP1 then SP2 before installing SP3...but then again, it is M$..LOL
        Next in line: RRMedia v2.0
        DFX 5.1.1 Skin
        Appstore Link
        My RideRunner Plugins
        RRMedia
        RRExtended
        DFXVoice
          *cough
          They are NOT service packs.
            I was more or less, using the SP's as merely something to compare it to. Yes, a bit of apples to oranges, but there are probably many that think the same...just install the newest/latest and should cover all bases, but doesn't in this case...
            DFX 5.1.1 Skin
            Appstore Link
            RRMedia
            RRExtended
            DFXVoice
              To be clear, I meant the actual service packs, as in ".Net 2.0 SP2", ".Net 3.0 SP1", etc. Everyone should have all 4 framework versions, with all service packs applied.
                I was testing on an XP SP3 platform this morning and didn't run any updates. The installer requested to install .NET 2.0 since I didn't have it. Maybe it should install .NET 3.5 instead? I know, I know, I should have all my updates installed.
                  Similar problem in Windows 7 64-bit
                  Hi all,
                  I cannot open RRconfig as the OP with the error message (attached). I am using Windows 7 64-bit. it supposed to include .Net framework 3.5 already. I also tried installing .Net 4 full version but doesn't help. Please kindly let me know what I am missing. Thanks in advance.
                  Cheers,
                  Jguy_ca
                    Jguy_ca,
                    Could you also post your rr.ini?
                      yes, your rr.ini is not in a format we expect...
                      one of your video / dvd settings
                      attach rr.ini (zipped, or rename to .txt)
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Sun, Come shine my way
                      Wind, Carry me home
                      The piece of me that died
                      Will return To live again
                        As attached. Thanks, guys.
                        Jguy_ca
                          fix
                          RRDVDDrive=
                          edit manually, to your optical drive...
                          your going to say, you dont have one, and thats ok...
                          just make it up
                          RRDVDDrive=E
                          ill fix rrconfig....
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Originally posted by mitchjs View Post
                            fix
                            RRDVDDrive=
                            just make it up
                            RRDVDDrive=E
                            Thanks Mitchjs for the tip. That solved my RRconfig issue. It turns out my RRISODrive is also pointing to wrong location. Problem fixed after manually edited both RRDVDdrive and RRISODrive.
                            Jguy_ca
