Check when RR send a ONSONGSTART command with autoit
  • Check when RR send a ONSONGSTART command with autoit
    How can i test when RR send a ONSONGSTART command with autoit.
    Actually, i add the line "ONSONGSTART","SENDMSG;ElcosMenu;UPDATEALBUMAR T" into my ExecTBL.ini file and
    the UPDATEALBUMART do what i want into the script .
    But i should like don't add a line into my ExecTBL.ini .
    Thanks for each help !
    You can add it to the main ExecTBL.ini OR to the skin's exectbl.ini but there's no way to do it otherwise. Only Extension plugins can track events/commands like that directly (and even so, they need to be in the plugins folder or loaded by the skin).
    Ride Runner RR's Myspace
      Ok, it's that i have already done and will continue to work like that !
      Thanks Guino
