RR 11-01-2011 Release
  • RR 11-01-2011 Release
    Where is this year gone... November already
    Download Here: http://www.nisuautomotive.com
    Just some Tweaks!
    FLASH 11.1.102.55 has been released by adobe, and its is compatable with RR's transparency.
    feel free to use
    Stay on FLASH 10.3 (see sticky), Flash 11 is a major change by adobe, and objects no longer are allowed to be
    rendered transparent, when using a non browser application, this is a fundamental change by adobe.
    we are looking at a new approach to flash objects
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    10/28/2011
    + Setting; "RRRadioSearchPresetsMain" determines of radio "searching for presets" will
      happen on the MAIN list(true) or auto switch to the LOCAL list(false)
      ex. RRRadioSearchPresetsMain=false  (default)
    10/26/2011
    + Skin Label; "RRAppName" returns the embedded application window information
    + User Var; "RRAppName" returns the embedded application window information
    10/20/2011
    # fixed issue with "minus1" introduced with ML
    10/13/2011
    # Prevention of hidden files from showing in DL
    # fixed DL folder issue with "." in the name
    # In DLs, songs turned into general list items (due to ML)
    10/9/2011
    # Audio Player; Windows Media Player, fix for visualization window showing before enabled
    # RRConfg, fixed .net assembly unload during plugin discovery
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Cool, i can't wait !
      nice thanxxxxxx
        Does exist a possibility to change the speed for the EFFECTIN OUT function !
          So many changes I need to be figuring out as I re-do my skin... eek! Good work though!!
          With the ML, would there be a way to have a section of text right aligned? Not just so many pixels from the right side (%TextX=-25%). That works great for a standard size field like the year, but wouldn't work for an Album title.
          03 Hyundai Elantra GT {Worklog}
          HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
          RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
          cmdRR tall skin creator
          86 Pontiac Fiero SE 2m6
          possible carpc install
            Makes for a lot of interesting programming ideas. Can't wait to test it.
              There seems to have a problem with the code that loads the loader.skin. I have the following "RRVER" and "STATUS" label which now shows up as very small fonts.
              L01,8,11,120,25,0,0,0,14,"Microsoft Sans Serif:B","RRVER","LEFT"
              L02,150,460,500,35,255,255,255,22,"Calibri:B","STA TUS","CENTER"
                I have often the same issue:
                You can change your font to arial without :B !
                  Loader issue is fixed in next release.
                  Check your loader.skin if you have line like this,
                  /, L, x, y, w, h,....
                  Remove it for now.
                    should be fixed in 11/4/2011 release, which is on nisu
                    just re-download/install rr as of 11/4...
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Originally posted by Enforcer View Post
                      First of all, check that the font you have in the skin file is on the system.
                      Yes, that's one of the first thing I check.
                        So i have an issue, but i'm not sure if it's RR or Win8 related..
                        RR won't auto start even though i have it in startup menu
                        and the radio module won't start most times..
                        Any ideas?
                        fresh install of win8 and everything else..
                          hehe, win8, well... as of today, we dont support win8
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            i know you don't 'support' it, i'm just testing it for you
                            so i've worked out that if i go into RR config, save and exit, then start RR, the radio works the first time. after that i have to go into Config again and save and exit, rinse, repeat...
                            I gather no one has that issue in win 7 then? might go back to win 7...
