Run RideRunner in a window instead of fullscreen
  • Run RideRunner in a window instead of fullscreen
    I was able to do this on older versions, but not with the latest version.
    I do development on my laptop, so I want to run RideRunner at the resolution I use in my CarPC, but instead of running in window inside my laptop's resolution, it resizes the system resolution and shrinks my entire desktop.
    I can't find a switch in RR config, either. Any ideas?
    Go into the skin's General.ini, and change the SHOW resolutions that RR resizes the skin to. Leave the ORIGINAL resolution alone.
    [Settings]
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    My Fiero Build Thread
      Do what he says above and alo make sure there's no resolution= line in rr.ini (this would make RR set the resolution while running).
      Ride Runner RR's Myspace
