Showing Filenames in Media Player Playlist window?
  • Showing Filenames in Media Player Playlist window?
    I want to show filenames in the playlist window. In the browser window, the filenames are displayed instead of ID3 tags, but even though I have ID3 tags turned off and have checked "Don't Format Text" in RRconfig, the playlist still won't show the filename.
    -Open RR.INI in notepad
    -Find "titlesafter=-" and set it to "titlesafter=" (remove the "-")
    -Save, test
    If you have don't format text, and ID3 tags disabled, that should be the only thing that can still modify the filenames.
    Note that this "titles after" is also in RRConfig right below the option to "Don't format text", if you remove it there and save it, it should also work.
    Ride Runner RR's Myspace
      -Save, test
      Thanks guino...much appreciated!
