RR 01-01-2012 Release - Happy New Year
  • RR 01-01-2012 Release - Happy New Year
    2012, i think we got till dec 21 then the world ends... prob most still wont have their car pcs done in time...
    Download Here: http://www.nisuautomotive.com
    Not too much here... some minor bug squashes...
    fix to the Cache folder not being created on 1st time installs...
    coulple new ONxxx Events
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    12/31/2011
    * Moved reload of RRPL.m3u8 to end of start up sequence.
    12/17/2011
    # fix for check for Cache folder existence, would fail to create on FRESH installs
    12/16/2011
    # Tweaks to Video load, added checks for missing or empty "videos.m3u8".
    + ONEvents; "ONLBLPRESS", "ONINDPRESS", "ONSLDPRESS".
    + User Var; "RRScreenObjectID" contains the resulting Screen Object (button, label, indicator, slider) ID.
      when OnEvent "ONBTNPRESS", "ONLBLPRESS", "ONINDPRESS", "ONSLDPRESS" is fired.
    12/14/2011
    + New option "OPT_NOFOCUS" for Screen Object Definition "AX", this will cause the embedded window
      to keep its focus even when RR skin is clicked on (no flashing of embedded window)
      ex. AX,0,0,800,450,"OPT_NOFOCUS"
          this will embedd the window at (0,0) 800 wide, 450 tall, with the NO_FOCUS option.
    + New option "OPT_BACKCOLOR#RRGGBB" for Screen Object Definition "AX", this will cause the embedded window
      background color to be set. (in most cases this is not needed)
      ex. AX,0,0,800,450,"OPT_BACKCOLOR#000000"
          this will embedd the window at (0,0) 800 wide, 450 tall, with the Black Background
    + Screen Object Definition; AX, eXtended Application embed area define
       ex. AX,0,0,800,450, "optionlist"
       options;
          OPT_NOTOUCH - do not remove window boarders
          OPT_NOFOCUS - do not lose focus on application when RR screen elements are clicked.
          OPT_BACKCOLOR#RRGGBB - set background window color to RRGGBB.
          OPT_PARENT  - embedded window parent window set to RR. (advanced)
          OPT_ATTACHINPUT - sets the embedded windows input proccessing to RR's. (advanced)
        ex. AX,0,0,800,450,"OPT_NOTOUCH,OPT_NOFOCUS"
    12/10/2011
    # tweaks to TagToTitle, for when tag data is missing
    + On error screen, pressing any key will exit the error screen
    12/9/2011
    # ML if tags data is missing, resulted in blank line (aka .cda files)
    # In All VB6 based Radio Modules, fixed bad reference to textbox object on numosk/osk skin
    12/5/2011
    # Custom source properly deactivated on suspend
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    I love the new A extended options . This is a great option !
    But, i don't understans the two options:
      Justed tested the new AX option with no8focus and thank for this great new option
        i moved the chinese unicode stuff to:
        http://www.mp3car.com/road-runner/15...ue-solved.html
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Hi,
          I have a issue that the music cannot start automatically, and no any album information shown in menu page, I need to click the MUSIC menu and the music then start (click the PLAY button still not start the music), I try to add the "StartCommand=AUDIO||EXIT" or "StartCommand=AUDIO||PLAY||EXIT" in RR.ini, but it still not start, after I add the StartCommand, the music can start when I click the PLAY button.
          RR in no album information when start. No music play even I click the PLAY button.
          Click image for larger version
          Music start when I click MUSIC Menu.
          and the album information can shown in menu.
          Add the "AUDIO||EXIT" or "AUDIO||PLAY||EXIT" into StartCommand, the album information shown in menu now, but music still not start, the music can play when I click PLAY button.
          Then, I clear the StartCommand and run the RR and click the MUSIC, after music start, I close the RR and open the RESUME.ini, the TrackPosition has value (I set the ResumeMusic=2 in RR.ini)
          Code:
          [Active Source]
          ActiveSourceID=5
          ActiveSource=Audio
          ActiveSourceGUID=5Audio5
          [Music Player]
          PLPosition=0
          TrackPosition=20827
          Now, I start the RR again and don't click any button/menu awhile, the music still not start, then I close the RR and review the RESUME.ini again. The TracePosition is changed.
          Code:
          [Active Source]
          ActiveSourceID=5
          ActiveSource=Audio
          [Music Player]
          PLPosition=0
          TrackPosition=20965
          Following code is RR.ini setting.
          Code:
          [Reminder Registration]
          RegCode=
          RegEmail=
          [Debuging]
          DebugMode=True
          DebugFresh=True
          XMDebug=False
          SRDebug=False
          RRAudPlayerDebug=False
          RadioDebug=False
          RadioExtDebug=False
          [General - Page 1]
          HideMouse=False
          HideTaskbar=False
          HideDesktop=False
          ScreenType=4:3
          FastMode=-1
          ScreenLimit=10
          ScreenRefresh=10
          Resolution=Default
          DisableDC=True
          EnableClipping=True
          DateFormat=Short Date
          TimeFormat=HH:MM:SS
          [General - Page 2]
          StartCommand=
          ExitMode=0
          Voice=False
          UseGestures=False
          LeaveMouseAlone=False
          UseCar2PC=False
          SoundCard=0
          MasterVolMap=0
          FadeInVolume=True
          StartUpVolume=-1
          MediaDrive=D
          UseDualMon=false
          [General - Paths]
          BrowserType=1
          BrowserPath=C:\Program Files\Internet Explorer
          LaunchPath=
          PicsPath=To set path, Click --->
          [General - Lists]
          UseDX=True
          iLSwapLR=False
          HideDots=False
          ShowIcons=False
          ShowExtensions=False
          PathLimit=True
          ListFollowsSong=True
          [General - Hibernation]
          HibernateAware=True
          ResumeDelay=0
          USBSound=False
          HORMDrive=
          [General - Gamma / Dimmer]
          GammaMode=2
          GammaPath=
          GPSGammaModeOffset=0
          GammaDay=0:0:0
          GammaNight=-50:-50:-50
          GammaDayTime=06:00
          GammaNightTime=18:00
          DimmerDay=0
          DimmerNight=30
          AutoGammaMode=0
          AutoSkinMode=2
          [General - Embbedded Applications]
          CloseApps=True
          EmbedAPPList=Zeitronix Data Logger
          [General - Screensaver]
          AVSTransparent=True
          FadeOnIdle=False
          SecondsToFade=300
          FadeInterval=10
          DefaultOpacity=40
          MaxOpacity=200
          [Skins]
          SkinPath=Carwings_Dynamic_Lite
          NightSkin=
          TransitionTime=0.2
          Transition=-1
          TransitionIn=-1
          TransitionOut=-1
          Background=
          [Preload Screens]
          [Audio Player - Player]
          Player=Winamp
          PlayerPath=
          HidePlayer=True
          ClosePlayerOnExit=True
          ExitMute=False
          [Audio Player - Paths]
          MusicPath=D:\MP3
          RRMusicBrowse=True
          PlaylistPath=D:\MP3
          AudioFiles=
          [Audio Player - Visuals]
          VisuName=!Winamp Gen!AVS
          TransparentVisu=True
          OpacityVisu=40
          [Audio Player - Winamp]
          WinampClass=
          RRWinampDisableLibrary=True
          UseLineInSingleInstance=True
          [Audio Player - Foobar2000]
          RRFooVisuShpeck=
          [Audio Player - Tags & Formatting]
          UseID3=2
          ShowID3Playlist=True
          ShowID3Browse=True
          LazyTag=False
          ID3ListFormat=%title% - %artist%
          ID3BrowseFormat=%title%
          NoFormat=False
          ListNumbers=True
          TitlesAfter=-
          ScrollMode=1
          [Audio Player - Art]
          AlbumArt=*.txt
          FadeImages=False
          [Audio Player - Modes]
          ResumeMusic=2
          AudioRepeat=Last
          AudioShuffle=Last
          CircularList=False
          GroupNumbers=False
          SingleClickAudio=False
          [Radio]
          Radio=
          AllowAllFreqs=false
          RadioLine=0
          RadioUseLineInPlugin=False
          RadioLineInPar=line://title=Radio,srate=44100,bps=16,nch=2
          UseRBDS=false
          RadioPort=
          [Radio - Cinergy 600]
          SeekLevel=0
          [Radio - WinTV]
          WinTVPath=
          [Radio - HD Radio]
          HDRadioType=Auto
          [Radio - UltimateDAB/FM]
          V7MTextColor=White
          [XM Radio]
          XMPort=0
          XMLine=0
          XMLineInPlugin=False
          XMLineInPar=line://title=XM,srate=44100,bps=16,nch=2
          XMUseCache=True
          SingleClickXM=False
          XMFormat=%station% %artist%
          [Sirius Radio]
          SRPort=0
          SRLine=0
          SRLineInPlugin=False
          SRLineInPar=line://title=SIRIUS,srate=44100,bps=16,nch=2
          SRUseCache=True
          SingleClickSR=False
          SRFormat=%station% %artist%
          [Video]
          VideoPlayer=WMPVidRR
          VideoPath=D:\Videos
          RRVideoBrowse=True
          VideoAutoHide=True
          VideoHideTime=1
          VideoFiles=.asf,.avi,.m2v,.mpeg,.mp4,.mpg,.nsv,.wm  v,.vob,.mkv,.rm,.rmvb,.flv
          VideoShuffle=False
          NoZoom=False
          [Video - Media Player Classic - Home Cinema]
          MPCHCPath=
          [Video - Media Player Classic]
          MPCPath=
          [DVD Player]
          DVDPlayer=WMPVidRR
          RRDVDDrive=
          RRDVDFoldersPath=D:\DVD
          RRDVDBrowse=False
          RRDVDISODrive=
          RRDVDISO=
          RRDVDISOMountCmd=
          RRDVDISOUnmountCmd=
          [Native GPS]
          GPSPort=20
          GPSTime=True
          UseGPSServ=False
          ISUnits=True
          Overspeed=100
          [Native GPS - Speed Controlled Volume]
          SpeedAtt=False
          SpeedAttMute=True
          SpeedAttMaxStep=100
          SpeedAttMode=line
          SpeedAttVolZero=70
          SpeedAttSpeedA=0
          SpeedAttSpeedB=70
          SpeedAttVolA=50
          SpeedAttVolB=100
          SpeedAttGainAt50mph=5
          [Navigation]
          GPSMode=2
          GPSPath=C:\Program Files\MapAsia\MapKing2007\MapKing2007.exe
          GPSName=!MapKingV7 Class
          [Navigation - iGuidance]
          igNative=False
          igAutoSw=False
          PauseOnVoice=False
          GPSOnVoice=False
          LastScreenSwitchTime=0
          [Extras]
          testpluginvar=defaultValue
          cityweather=Hong Kong,CN
          cityweatherid=HK
          weatherunits=WORLD
          weatherdegrees=
          weatherlanguage=english
          weatherupdateinterval=0
          weatherpreset01=香港
          weatherpresetid01=Hong Kong,CN
          weatherpreset02=
          weatherpresetid02=
          weatherpreset03=
          weatherpresetid03=
          weatherpreset04=
          weatherpresetid04=
          weatherpreset05=
          weatherpresetid05=
          weatherpreset06=
          weatherpresetid06=
          weatherpreset07=
          weatherpresetid07=
          weatherpreset08=
          weatherpresetid08=
          weatherpreset09=
          weatherpresetid09=
          weatherpreset10=
          weatherpresetid10=
          weatherundergroundkey=
          radiouasinput=0
          xmuasinput=0
          sruasinput=0
          mapmonkeypath=Click here to set path
          mappointmap=1
          mapcountry=Hong Kong
          mapcity=
          mapautozoom=true
          phidget1=0
          phidget2=0
          phidget3=0
          phidget4=0
          phidget5=0
          phidget6=0
          phidget7=0
          phidget8=0
          tcomport=0
          tempscale=c
          temp1=c
          temp2=c
          temp3=c
          temp4=c
          vcomport=
          Anything wrong in my setting?
          Thanks!
            1st off, dont do startcommand "AUDIO||EXIT" or anything like that!!!!
            let RR play the music when it should.... which if resumemusic=2, it will...
            i wont look at you rr.ini settings in detail, if you ever want me to please attach as a .zip
            on a side note, unless thats a remote desktop screen capture, i can see directx isnt working for you... by the look of the screen shot
            and all the information you need to solve your problem is in debug.txt, and if you're going to post one, please attach not paste in!
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              Hi, I am running the RR in VM to test all feature, will it affect the result?
              I set the resumemusic=2 already, and I try to reinstall the DirectX 9.0c again, but the situation still unchanged.
              I attach the debug.txt, resume.ini, rr.ini and rrpl.m3u8 to you.
              I try to unhide the winamp for checking, the song name is shown int winamp but all play/previous/next/stop/pause are diabled.
              Thanks!
                I discover that when I click into skin, e.g. GPS and then close, the music will start, I try to click the menu2.skin, the music will start too.
                  vm, directX wont work, so thats the ilist issue
                  it will use normal lists
                  i use VM sometimes too, no issues resuming...
                  maybe you have an issue with winamp
                  yours:
                  10/1/2012 12:30:40: PLAYER: Started
                  10/1/2012 12:30:40: PLAYER: Winamp Version:
                  10/1/2012 12:30:40: PLAYER: Initialization complete
                  mine:
                  1/11/2012 10:09:27 PM: PLAYER: Started
                  1/11/2012 10:09:27 PM: PLAYER: Winamp Version: 5.61
                  1/11/2012 10:09:27 PM: PLAYER: Initialization complete
                  mine:
                  1/11/2012 10:09:31 PM: PLAYER: Restored rrpl.m3u8
                  1/11/2012 10:09:31 PM: CheckResume: ResumeMusic=1 WasRadio=0
                  1/11/2012 10:09:31 PM: AudPlayerStart: music player: PLPosition=0 TrackPosition=3467
                  1/11/2012 10:09:31 PM: AudPlayerStart: player volume be 0: 0
                  1/11/2012 10:09:31 PM: AudPlayerStart: player should be playing: PLAYING
                  1/11/2012 10:09:32 PM: AudPlayerStart: Player.GetTrackLength: 970000
                  1/11/2012 10:09:32 PM: AudPlayerStart: Player.SetTrackPosition: 3467
                  1/11/2012 10:09:32 PM: CheckResume: Resuming to music player: PLAYING
                  as you can see right after the playlist is restored... im playing....
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    In my VM environment, sometime the music resume when the RR start, sometime I need to click "SOMETHING" (the iLIST is off), in my actual PC, seem it is OK when I enable iLIST.
                      I just installed this from the November version and I'm having a problem with audio information.
                      I am using the eLite 2 skin.
                      Song information will display on every screen, at the top, however when the song changes it disappears for a second or two and doesn't switch smoothly like before.
                      If I am on the audio_player.skin only the information for the first song of the playlist will show, any other songs ALL information is blank except for track number and quality level.
                        OK, i see an issue... i will contact you
                        m
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          I believe I am encountering the same problem. I installed the newest version and I'm running the Reborn skin. Before I had scrolling song titles on the music page, and now I no longer do. Whats the fix?
                            mitchjs has found and fixed the problem. I'm not sure if I'm allowed to provide you with the link, username, and password so I'll wait for him to chime in, but be assured once you get the new version it "should" work correctly!
                              no dont post my personal ip and passwords!!!!!
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
