Best way to emulate mouse clicks
  • Best way to emulate mouse clicks
    I recently added a skin for my iPhone so I can interact with it without having to look down at. With touchscreens, if you press long enough, it acts as a right mouse click, but I need some functionality beyond that.
    I need to be able to right click for a short duration and I also need to be able to right click twice in a row and that cannot be done with the touchscreen mouse click emulation.
    At a minimum, I can install my macro recorder/player and compile a .exe which will simulate the mouse events that I need, but that seems like overkill. Is there a way to do this through RR directly?
    (For those that want to know, its a jailbroken iPhone running "veency" and I just use a command line for UltraVNC on a button to launch this skin)
    Click image for larger version
    There is nothing directly in RR that can do that.
    You could do a AutoIt script or a RRPlugin.
    Although I'm still not quite sure exactly what you need to do.
    If you just need to run UltraVNC then you can set up a button to run an exe with command line parameters
      Macro it is! Thanks.
      Yup, this is what I already do.
        Added the buttons for the macros to simulate iPhone commands and it works awesome. I am running the embedded vnc session at 256 colors because it makes for faster screen transitions. I am connected via an adhoc wifi link.
