Some user interface problems in RRConfig
  • Some user interface problems in RRConfig
    Hi guys,
    i notice some problems with the last RRConfig version...
    when i click on "Launch RRReg", i get this error
    Click image for larger version
    Plugin section doesn't show anything
    Component used to set start/end time of skin changing, doesn't show the time, but only the date (calendar format)
    is there already a new fixed version ?
    hope to help you to improve RideRunner
    The dll registartion problem is talked about here http://www.mp3car.com/rr-faq/137616-...er-screen.html
    Hopefully someone can add to the plugin problem because I have the same issue and couldn't tell if I was doing something wrong or if it was a bug.
      Ok...
      ok, i solved the problem with mswinsck.ocx ...now i'm able to use "Launch RRReg" without problem....
      the right folder where to put mswinsck.ocx, on Windows 7 64 bit systems, is "C:\Windows\SysWOW64"
      i know that probably no one CarPc uses 64 bit Operative System, but maybe some user makes RideRunner's test on that system....
      maybe Guino can update "Faq 3d" with this information
      for the other points, no idea?
        plugins wont show ANYTHING unless there is a PLUGIN that supports RRCONFIG...and only 1 does MY MJS UAS4, i actually never released any details one how one would create a settings option, cause each programmer of thier own plugins have thier own setups... usually edited a .ini file
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          as for the time...edit it manually
          and ill eventully look at fixing it to a time picker
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            sure, i understand...
            I don't thought about that...;-)
            Inviato dal mio GT-I9100 usando Tapatalk
              Yes, i edited manually... that's was just a notification ;-)
                How are plugins supposed to support RRCongig?
                  e, its hard to explain... you know us programmers...no documentation...
                  but we put the support in to RRConfig...
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    tommy all fixed... thanks pAL!
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      yes, i know....i'm programmer too
                      Thanks for the fix...this evening i'll try it
