RR 02-05-2012 Release
  • RR 02-05-2012 Release
    Updated for embedding of iGuidance (4.x tested)
    ALSO an internal change on how "back" and ".." work when browsing files...
    (allows for better browse.rrl experiences)
    Download Here: http://www.nisuautomotive.com
    Fixed a bunch of little things, thanks to tommy in italy! (tommy_xx84)
    some minor fixes in RRConfig too
    dont forget read the history!
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    02/05/2012
    # Issue fixed for finding iGuidance window
    ! Fundamental change in how ".." / "back" command works in file browser
    02/2/2012
    + Screen Object; Textbox now supports alignment. "left" (default), "center", "right"
      ex.T01,225,25,350,56,0,0,0,200,200,200,38,"Arial Narrow:B","TEXTBOX","CENTER"
    02/1/2012
    # XML file issue in weather plugin, now properlly saves unicode files
    01/28/2012
    * Tweaks to OPT_PARENT for keeping application visable when a MENU POPUP happens
    01/26/2012
    + Skin Command; "ACTIVATE" (no arugments) Activates the current screen's embedded application
    + UserVar; "RRAppHwnd" is the window handle of the current screen's embedded application
    + Skin Label; "RRAppHwnd" shows the window handle of the current screen's embedded application
    01/24/2012
    # Custom Source issue when more than 1 custom source
    01/21/2012
    * Skin Indicator "heading" changed to "RRGPSHeading"
    + Skin Label; "RRGPSHeading" shows "N", "NE", "E", "SE", "S", "SW", "W", "NW"
    01/17/2012
    + Tweak to Tag reading when song changes
    # Fixed incorrect Title data in Playlist(), cause no tags from being read in
    01/16/2012
    + Tweak to iList Memory usage
    01/11/2012
    + Some minor debug.txt additions + a slight look change to some entries (testing)
    01/09/2012
    * Tweak for embedding of windows in skin, to allow for when a skin is a centered popup menu
    01/08/2012
    * Updated the SkinTool, see its history file for details
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks for this new version :-)
      Include the Heading function into the RR core is a very good initiative but, with the old version the .png files was into a Indicators folder that was a good thing !
      Now , the .JPG files must to be into the skin folder if i don't say a joke ?
        HU? what are you talking about
        if you are talking about "heading" "RRGPSHeading" INDICATOR NOTHING HAS CHANGED
        they always been .jpgs and they ALWAYS have been required to be in SKINPATH
        only a new proper name has been added "RRGPSHeading" to deprciate the vague "heading"
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Sorry, i think that i confised with the RRextended heading option !
            Where would we be without you Mitch. Thank you for filling our wishes and keep the wheels turning.
              Yes, that is correct, RRExtended's GPSHeading had a setting to specify a folder anywhere for the indicators. Guess I spoiled em...haha
              Next in line: RRMedia v2.0
              DFX 5.1.1 Skin
              Appstore Link
              My RideRunner Plugins
              RRMedia
              RRExtended
              DFXVoice
                Going through on my test machine setting up my skin revisions and now with 02-02-2012 RR installed iGuidance doesn't embed properly.
                Works fine with Jan 2012 RR. Pictures will explain more.
                I've tried the various AX options with no luck.. iGuidance will always show like that. Even worse if I click the iGuidance windowswitch icon. Doesn't make a difference if I'm in the external_gps skin or the external_gps_full skin.
                January
                February
                Any thoughts?
                03 Hyundai Elantra GT {Worklog}
                HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
                RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
                cmdRR tall skin creator
                86 Pontiac Fiero SE 2m6
                possible carpc install
                  fixed...
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    it definitely is
                      Originally posted by mitchjs View Post
                      fixed...
                      Thank you.
                      Mike
                      My Rides:
                      '03 Vibe GT!
                      My AED GA!
                        Hi all,
                        This version of RR cannot resume playing the last song when the song is under a Chinese title or stored in an artist foldername in Chinese. No problem resume playing if it's an English song. I didn't have this problem when I was using DEC-2011 version of RR. Please kindly help. Thank you.
                        Jguy_ca
                          I JUST tested a chinese song in a chinese folder and it plays and when i restart RR, it resumes perfectly
                          using WINAMP 5.61 as my player
                          test, with carwings too...case its a skin issue!
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            Appreciate your help, Mitch. I did test against Carwings before posting here. Same problem. My folder structure is Music / "Artist name" (Chinese) / "Album name" (Chinese) / "Songs" (Chinese). English songs goes under: Music / English Songs / "Artist name" / "Album name" / "Songs". I checked resume.ini after it cannot resume and it shows Trackposition=-1. I also reinstalled Winamp 5.6.23 with default settings.
                            As mentioned no such problem in Dec release with any skin I used. I don't have the setup file anymore. Anywhere I can download it again?
                            Jguy_ca
                              you cant(publicly), we dont go backwards, only forwards.... i cannot reproduce your issue... i have plenty of chinese music thats to a few people here, and it always resumes to the same position
                              did you read debug.txt? it will tell you what its doing
                              trackposition=-1 means something... i cant remember exactly right now, but it does mean, that RR could NOT get the posititional data from winamp
                              like you are killing the winamp process before RR is closed, which there is some safety code in rr, to try to use the last known positional data from winamp
                              so.. maybe you can FTP me that perticuar song, and let me see your debug.txt
                              if there is an issue, ill fix immediatly but it has to be reproducable
                              pm me for FTP information
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
