Save a text into the clipbard from a form with the B.NET Clipboard.SetDataObjec
  • Save a text into the clipbard from a form with the B.NET Clipboard.SetDataObjec
    Hello,
    In my future RRGoogleMapsTools plugin , i need to save a text (latitude, longitude) from a window
    when i click on a google maps point .
    So, i have tried firstly to add a clipboard option into my html file by that don't run .
    Secondly, i have tried the VB.NET Clipboard.SetDataObjec function as:
    Code:
    Clipboard.SetDataObject(frm.tag, True)
    But that return me the RR screen name 'RRGoogleMapsTools.skin'
    course it will, thats the contents of "frm.tag" its just a string
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      That don't help me mitchjs !
      I have found a solution on the web !
      Code:
                  Case "gmaps_setclipboard"
                      SendKeysToApplication(vbNullString, "GmapsApiForm", "^c")
                      'Get the data stored in the clipboard
                      Dim iData As IDataObject = Clipboard.GetDataObject()
                      'Check to see if the data is in a text format
                      If iData.GetDataPresent(DataFormats.Text) Then
                          'If it's text, then paste it into the textbox
                          CMD = "SETVAR;RRGoogleMapsToolsInfo;A gps coordinate is saved .<crlf>You can use the 'Point To '" & SDK.GetInfo("gmaps_gpsname") & "command ...||menu;RRGoogleMapsTools_info.skin"
                      Else
                          'If it's not text, print a warning message
                          CMD = "SETVAR;RRGoogleMapsToolsInfo;Please, select the Gps coordinates before<crlf>to use this function ...||menu;RRGoogleMapsTools_info.skin"
                      End If
                      gps = Split(CType(iData.GetData(DataFormats.Text), String), ",")
                      CMD = "SETVAR;GPSLATCLIP;" & CStr(Math.Round(Val(gps(0)), 6)) & "||SETVAR;GPSLONCLIP;" & CStr(Math.Round(Val(gps(1)), 6)) & "||SETVAR;ADDRESSCLIP;" & getGoogleMapsReverseGeocode(CStr(Math.Round(Val(gps(0)), 6)), CStr(Math.Round(Val(gps(1)), 6)))
                      Clipboard.Clear()
                      ProcessCommand = 3
      The red line does a CTRL C on the selected line and the blue line give me the result !
      Another way for get the clipboard value is 'My.Computer.Clipboard.GetText()' .
        messy if you ask me...
        your going to drive me crazy with all your SETVARS!!!
        use... SDK.SetUserVar("varname", value)
        its instant, and less work for RR
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          In the majority case, i use the SDK.SetUserVar command ! But infact, here i had forgotten that !! oops
