USB UK/Europe AM/FM radio for ride runner
  • USB UK/Europe AM/FM radio for ride runner
    Been looking around the forums and tried google, but drawn a bit of a blank on this one.
    I looking for a USB am fm radio module that will work with RR, I've been reading about the "silabs" chip being supported but not sure what current manufuacture/models use this supported chipset.
    Anyone in the euro zone help with this.
    Thanks.
    You could try and find ADS instant fm it is based on that same radio module. hope this helps SNO
      i found some on ebay for $10 while back.. look there
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        I've found an "ADS Tech RDX-155 Instant FM Music" on ebay but all the sellers are in the USA, are there US & Euro versions of this product?
          There is only 1 model. Nothing needed to run it in the uk. It will work just fine. The hardest part of using that module is getting a good antenna connection. SNO
            Farnell sell them
            http://uk.farnell.com/silicon-labora...ick/dp/1186925
            Unit Price: 32.53 + VAT
            Expensive and you will probably be dissapointed with the reception so building a Venice 5, Venice 7 or Verona based DAB/DAB+/FM RDS radio might be better a option for you. You might have to build it yourself or get someone to do it for you.
              wow 32.50 I just got one off ebay for 12.00 delivered from the US, reception not to bothered at the moment as this is just for bench testing, I need to look at adapting the Antena system installed in my Audi A4.
              I do like RS & farnell, but there prices are shocking ...
              Will take a look at the Verona, should be able to build one as long as I can get the parts.
                Getting the Verona module is not that difficult, just find a radio donor that has a confirmed verona inside. The rest of the parts can be found in farnell/rs/ebay.
                Get a V5 if you want slave, get a Verona or V7 if you want CB compatible radio.
                  hi guys, can you confirm it? is ADS Tech RDX-155 Instant FM USB 2.0 Radio working with RR, cheers
                    I can confirm ADS Tech RDX-155 Instant FM USB 2.0 Radio works ok with RR, you need to select Silabs radio when you install RR. ADS use Silabs chip.
                    Yo-yo antenna which come with ADS stick is crap, but with decent car antenna this can be a reasonable radio.
                    Though there is real car radio available, Directed HMHD1000I AM/FM/HD with MJS Interface Cable.
                      Thanks, Dartman ...HMHD1000I AM/FM/HD looks great but price so far trying to figure out how to make RR working with my hw (a bit pain in my back )
