RR 03-02-12 Release
  • RR 03-02-12 Release
    So its March...the year is flying by, even with the "leap" day...
    Download Here: http://www.nisuautomotive.com
    Fixed a bunch of little things...some old bugs... thanks to Dartman_71
    some minor fixes in RRConfig too
    Weather Plugin, has an improved RRConfig addon.
    Highlights:
    • Skin Command; "IFVAR" variable to variable compare (equals or not equals only)
    • Skin Command; EVENT: "ONDIRDBLCLICK" fires when a DIRectory is double cicked on (SD file browser lists)
    • On intial show of a list, LISTxxxx user variables are now refreshed
    • "resume.ini" is now a unicode file(UCS2-LE) this allows unicode paths/filnames inside(last browse paths)
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    2/26/2012
    # On intial show of a list, LISTxxxx user variables are now refreshed
    2/24/2012
    + Skin Command; EVENT: "ONDIRDBLCLICK" fires when a DIRectory is double cicked on (SD file browser lists)
    + Skin Command; "Band;AM" direct switch to AM (HD Radio only)
    + Skin Command; "Band;FM" direct switch to FM (HD Radio only)
    2/20/2012
    * "resume.ini" is now a unicode file(UCS2-LE) this allows unicode paths/filnames inside
    2/16/2012
    # Tweaked "back", properlly goes back, and now sets previous item selected
    2/12/2012
    - Skin Command/Indicator "winamppreampmute" removed (no such function in winamp).
    # Skin Command/Indicator "PlayerEQ" correctly toggles player EQ on/off, and shows correct state.
      (is also a clickable indicator)
    # Skin Command/Indicator "AutoEQ" now shows correct state (on = true).
    2/11/2012
    # Fixed issue where activesource when on a radio_player skin, could get set to audio
    2/8/2012
    # Fixed Start Audio source issue, would seemly cause rr to freeze (momentarlly)
    2/7/2012
    + Skincommand; "IFVAR" variable to variable compare (equals or not equals only)
      ex. "IFVAR;myvar==myothervar;DOTRUE<<DOFALSE"
          "IFVAR;myvar!==myothervar;DOTRUE<<DOFALSE"
      (note the double = (equal), denotes a var to var compare)
    02/06/2012
    # Tweak to skin command "HIDECONTROLS" to not move the cursor out of resolution of display
    02/05/2012
    # Issue fixed for finding iGuidance window
    ! Fundamental change in how ".." / "back" command works in file browser
    02/2/2012
    + Screen Object; Textbox now supports alignment. "left" (default), "center", "right"
      ex.T01,225,25,350,56,0,0,0,200,200,200,38,"Arial Narrow:B","TEXTBOX","CENTER"
    02/1/2012
    # XML file issue in weather plugin, now properlly saves unicode files
    # Fix to installer for PLabs (digitalCar Radio) install folder
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    NOTE, for those people using WeatherUnderground (Weather plugin)
    if using a Language translation...
    in rr.ini, my advice is set rr.ini setting to
    WeatherLanguage=
    to not use the language translation file,
    but use the NEW WeatherUndergroundLangID= setting
    to have WeatherUnderground.com give you back data in the language you want...
    RRConfig v1.0.7, has all the IDs in the new Weather Plugin Config area, or visit the WeatherUnderground.com API Page
    example: (Italian)
    WeatherUndergroundLangID=IT
    yes, the old translation support is still there, but leaning towards obsolete, at the very least depreciated
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
      Cool, another version
        thanks for the new version,
        now my mixer indicator works the right way.
          *deleted*
            It's possible to know how to create a RRconfig plugin please ?
              I have an issue with my indicators into my last plugin that are superimposed !
              my code is:
              [INDICATORS]
              I01,266,10,53,53,"GMAPS_LIST_EXIST",,,""
              I02,575,12,42,40,"ONLINE",,,""
              I03,634,12,30,40,"MOBILEPHONE_CONNECTED",,,""
              I04,518,10,48,48,"GMAPS_GPSOK",,,"Indicators\gpsok _*.png"
              I05,736,191,44,40,"GMAPS_MOBILEPHONEOK",,,"Indicat ors\mobilephone_*.png"
              I06,555,199,90,25,"GMAPS_CLIPBOARDOK",,,"Indicator s\sendtorr_*.png"
              I07,663,193,54,36,"GMAPS_SKYPEOK",,,"Indicators\sk ype_*.png"
              I08,7,544,62,53,"MUTE:b",,,""
              I09,667,409,64,18,"GMAPS_GPSCOOROK:b",,,""
              I10,730,409,64,18,"GMAPS_GPSITINERYOK:b",,,""
              I11,614,435,39,39,"GMAPS_VARTYPETOSEND",,,"Indicat ors\gmapsvartypetosend_*.png"
              I12,608,486,52,9,"GMAPS_TIMERS:b",1000,500,""
              I13,426,502,27,27,"FILE;$skinpath$Indicators\gmaps vartypetosend_00.png"
              What is my error please ?
                Installed latest release and RRConfig throws an error on startup and when I try to use any of the buttons (save, exit, etc). The error is:
                Code:
                See the end of this message for details on invoking
                just-in-time (JIT) debugging instead of this dialog box.
                ************** Exception Text **************
                System.ArgumentOutOfRangeException: Value of '120' is not valid for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'.
                Parameter name: Value
                   at System.Windows.Forms.NumericUpDown.set_Value(Decimal value)
                   at RRConfig.nodeGPSServicesNative.DeserializeThisFormFromINI()
                   at RRConfig.ConfigForm.DeserializeFromINI()
                   at RRConfig.ConfigForm.DeserializeChildNodesFromINI()
                   at RRConfig.MainForm.MainForm_Load(Object sender, EventArgs e)
                   at System.Windows.Forms.Form.OnLoad(EventArgs e)
                   at System.Windows.Forms.Form.OnCreateControl()
                   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
                   at System.Windows.Forms.Control.CreateControl()
                   at System.Windows.Forms.Control.WmShowWindow(Message& m)
                   at System.Windows.Forms.Control.WndProc(Message& m)
                   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
                   at System.Windows.Forms.ContainerControl.WndProc(Message& m)
                   at System.Windows.Forms.Form.WmShowWindow(Message& m)
                   at System.Windows.Forms.Form.WndProc(Message& m)
                   at RRConfig.MainForm.WndProc(Message& m)
                   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
                   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
                   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
                ************** Loaded Assemblies **************
                mscorlib
                    Assembly Version: 2.0.0.0
                    Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
                    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
                RRConfig
                    Assembly Version: 1.0.0.7
                    Win32 Version: 1.0.0.7
                    CodeBase: file:///C:/Program%20Files/RideRunner/RRConfig.exe
                    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
                System
                    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
                System.Drawing
                    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
                System.Core
                    Assembly Version: 3.5.0.0
                    Win32 Version: 3.5.21022.8 built by: RTM
                    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
                System.Xml
                    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
                RRConfigPluginWeather
                    Assembly Version: 1.0.0.0
                    Win32 Version: 1.0.0.0
                    CodeBase: file:///C:/Program%20Files/RideRunner/Plugins/Weather/RRConfigPluginWeather.dll
                Accessibility
                    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
                ************** JIT Debugging **************
                To enable just-in-time (JIT) debugging, the .config file for this
                application or computer (machine.config) must have the
                jitDebugging value set in the system.windows.forms section.
                The application must also be compiled with debugging
                enabled.
                For example:
                <configuration>
                    <system.windows.forms jitDebugging="true" />
                </configuration>
                When JIT debugging is enabled, any unhandled exception
                will be sent to the JIT debugger registered on the computer
                rather than be handled by this dialog box.
                  I have already ask this question.
                  Is it possible to add the same tooltip option <crlf> as MIDDLE for the WRAP and WRAP-RIGHT , that would be a very cool option !!!
                  Thanks for all your job on RR.
                    my code is:
                    Ok,
                    I have worked a little bit on this indicator's issue and found that RR don't accept differents indicators format:
                    So i have used if possible the format:
                    I01,267,10,53,53,"GMAPS_LIST_EXIST",,,"Indicators\ gmaps_itn_*.png"
                    and not
                    or
                    I01,266,10,53,53,"GMAPS_LIST_EXIST",,,"" .
                    So, the solution that run well for me is:
                    [INDICATORS]
                    I02,581,16,37,37,"ONLINE",,,"Indicators\online_*.p ng"
                    I03,630,14,30,42,"MOBILEPHONE_CONNECTED",,,"Indica tors\bt_*.png"
                    I13,426,502,27,27,"",,,"Indicators\gmapsvartypetos end_00.png"
                      @eribs4e
                      Can you please post your rr.ini?
                        Originally posted by rtgree01 View Post
                        @eribs4e
                        Here you go:
                        Code:
                        [Debuging]
                        debugmode=false
                        debugfresh=false
                        xmdebug=false
                        srdebug=false
                        radiodebug=false
                        [Audio Player Setup]
                        player=WINAMP
                        playerpath=
                        hideplayer=true
                        closeplayeronexit=true
                        exitmute=true
                        [General]
                        launchpath=
                        voice=false
                        showicons=false
                        showextensions=false
                        hidemouse=false
                        hidetaskbar=false
                        hidedesktop=false
                        hidedots=false
                        gpstime=false
                        exitmode=0
                        dateformat=Short Date
                        timeformat=Short Time
                        screentype=4:3
                        enableclipping=true
                        nozoom=false
                        pathlimit=true
                        usegestures=false
                        leavemousealone=false
                        closeapps=true
                        fastmode=-1
                        usedualmon=true
                        soundcard=0
                        screenlimit=0-
                        mastervolmap=-1
                        hibernateaware=true
                        resumedelay=0
                        usbsound=false
                        browsertype=0
                        usevoicecontrol=false
                        usecar2pc=false
                        fadeinvolume=true
                        usedx=true
                        ilswaplr=false
                        picspath=To set path, Click --->
                        disabledc=false
                        [MJSG UAS]
                        radiouasinput=0
                        xmuasinput=0
                        sruasinput=0
                        [Skins]
                        skinpath=C:\Program Files\RideRunner\Skins\Carwings_Dynamic\
                        nightskin=C:\Program Files\RideRunner\Skins\Carwings_Dynamic\
                        transition=-1
                        background=C:\Program Files\RideRunner\Backgrounds\Brushed Metal Dark.jpg
                        TransitionTime=0.2
                        [Gamma]
                        gammamode=4
                        gpsgammamodeoffset=0
                        gammaday=0:0:0
                        gammanight=-50:-50:-50
                        gammadaytime=6:00
                        gammanighttime=15:00
                        dimmerday=0
                        dimmernight=30
                        autogammamode=2
                        autoskinmode=2
                        [Preload Screens]
                        [Music]
                        musicpath=D:\Music Library\
                        playlistpath=D:\Music Playlists\
                        useid3=2
                        showid3playlist=true
                        showid3browse=true
                        lazytag=false
                        singleclickaudio=false
                        noformat=false
                        listnumbers=false
                        listfollowssong=true
                        id3listformat=%title%
                        id3browseformat=%title%
                        titlesafter=-
                        albumart=*.txt
                        fadeimages=false
                        audiofiles=.m3u,.mp3
                        scrollmode=1
                        circularlist=false
                        groupnumbers=false
                        resumemusic=2
                        audiorepeat=false
                        audioshuffle=false
                        [Visualization]
                        visuname=MilkDrop
                        transparentvisu=false
                        opacityvisu=40
                        [Radio]
                        radio=HDRadio
                        allowallfreqs=false
                        radioline=0
                        uselineinplugin=true
                        lineinpar=line://title=Radio,srate=44100,bps=16,nch=2
                        uselineinsingleinstance=false
                        userbds=false
                        RadioPort=1
                        HDRadioType=Directed
                        [XM]
                        xmport=0
                        xmline=0
                        xmlineinplugin=false
                        xmusecache=true
                        singleclickxm=false
                        xmformat=%station% %artist%
                        [SIRIUS]
                        srport=0
                        srline=0
                        srlineinplugin=false
                        singleclicksr=false
                        srusecache=true
                        srformat=%station% %artist%
                        [Video Player Setup]
                        videoplayer=
                        mpcpath=
                        [Video]
                        videopath=E:\Movie Library\
                        videoautohide=true
                        videohidetime=4
                        videofiles=.asf,.avi,.m2v,.mpeg,.mpg,.nsv,.vob,.wm  v
                        videoshuffle=false
                        [DVD Player Setup]
                        dvdplayer=WMPVidRR
                        [TV]
                        tvline=0
                        [GPS]
                        gpsmode=2
                        mapmonkeypath=Click here to set path
                        gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe
                        gpsname=iGuidance
                        overspeed=120
                        gpsport=0
                        mappointmap=1
                        mapcountry=United States
                        mapcity=
                        mapautozoom=true
                        isunits=true
                        usegpsserv=false
                        gasfinderautorefresh=false
                        [IG Native]
                        [Speed Att Vol]
                        speedatt=false
                        [Phidget]
                        phidget1=0
                        phidget2=0
                        phidget3=0
                        phidget4=0
                        phidget5=0
                        phidget6=0
                        phidget7=0
                        phidget8=0
                        [4 Temps]
                        tcomport=0
                        tempscale=c
                        temp1=c
                        temp2=c
                        temp3=c
                        temp4=c
                        [Volt Meter]
                        vcomport=
                        [Phone]
                        phoconodesign=false
                        motophone=false
                        phonelistspath=Click here to set path
                        contactspicturespath=Click here to set path
                        ringtone=Click here to set path
                        smstone=Click here to set path
                        maxcalllistentries=100
                        phoconoincallevent=false
                        connecthsp=true
                        standardphonebook=0
                        phonebooksencoding=windows-1252
                        [Weather]
                        cityweather=New York,NY
                        weatherunits=USA
                        weatherdegress=
                        localdatacaptureinterval=0
                        [Extra's]
                        hddebug=false
                        disableinternat=false
                        locale=0
                          Try changing the value of the "overspeed" value to a number from 0 to 100.
                          This shouldn't be an issue for the next release...
                            I have added the locate command to the skin !
