Slider help required
  • Slider help required
    Good evening all,
    I'm having a few problems getting sliders to work from plugins (the two I've tried are "wifiman_signal" and "DFXVOICE_SCANPROGRESS" allbeit DFXVoice is under development). The code used with the single image file is:
    S,461,258,300,22,461,258,300,22,,"DFXVoiceslider.p ng",,,"DFXVOICE_SCANPROGRESS",
    If I replace "wifi_signal" or "DFXVOICE_SCANPROGRESS" with "SONGPOS", the sliders works as advertied.
    Any advice would be welcomed .
    TIA,
    Dave
    Vauxhall Astra SXi Car PC installed.
    Skin tool doesn't see a value either
      Bump before the holidays
        skintool, technically is a plugin, and if its loaded before the said plugin, it wont be able to show you a plugin's slider
        if you follow my drift
        as for the two sliders you mention, im not familar with both...you actually need help with the wifiman plugin i guess
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
