RR 04-01-2012 Release
  • RR 04-01-2012 Release
    OK, should i say we going back to the Road Runner name? i think i already used that April fools joke..
    April already? sheeze, time does fly faster the older you are!
    Download Here: http://www.nisuautomotive.com
    The biggest thing here is the Dynamic Menus, I should have done this code years ago
    removes tons of cryptic Exectbl.ini code, and allows plugins(if the plugin supports it)
    to have a menu automatically available to the user
    the dynamic menu system is completely demonstrated in the Carwings_Dyanamic_lite
    skin installed by the installer
    see the thread: http://www.mp3car.com/road-runner/15...mic-menus.html
    Highlights:
    • + Dynamic Menus
    • + Skin Object; "RG" Clickable Region - RG,x,y,w,h,"CODE"
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    3/29/2012
    + Skin Label; "ByIndX" support added.
      ex:   L,x,y,w,h,"ByIndX;indicatorcode;(false<<true)"
      ex:   L,x,y,w,h,"ByIndX;MJSG_1Wire;Adaptor;(=<<=1-Wire Installed)"
      ex:   L,x,y,w,h,"ByIndX;Online;(=Disconnected<<=Connected)"
            (shows "1-Wire Installed" when indicator "MJSG_1Wire;Adaptor" is true)
    + Skin Label; "ByVarX" support added.
      ex:   L,x,y,w,h,"ByVarX;myvar;(=Zero<<=One<<=Two<<=Three)"
    		(shows "Two" when value of UserVar "myvar" is 2)
    * Skin Label; if they are of the "ByVar, ByVarX, ByInd, ByIndX"
                  they are now correctly supported outside of a physical skin,
                  ie in skintool or other plugins.
    + Allow window targeting of the parented embedded window on the video/dvd player screen.
      ex:	sendwmcommand;!MediaPlayerClassicW!;952;0
            (would target MPC-HC and send the WM_COMMAND 952 (next audio))
    3/22/2012
    # Skin Indicator; "OverSpeed" now takes in account setting IsUnits
      (before the value was in KNOTS!)
    3/18/2012
    * Added one additional Splash screen status label status, after loading the last preloaded screen
    3/16/2012
      This is clickable anywhere at anytime(as long as rr is visable), even on top of application windows
      ex:  RG,0,0,800,20,"ESC"   creates a clickable region 800px wide x 20px high at 0,0
                                 when clicked command "ESC" is run
    + Skin Event; "ONRGNPRESS" event for "RG" clickable region command.
    3/13/2012
    # fixed iPOD database read, caused RR to freeze
    3/8/2012
    # FMPresets folder failed to create on 1st time use
    3/7/2012
    + Dynamic Menus: (see New Dynamic Menus.txt)
        Skin Command:   "RRMenuItem;x;[set]"
        Skin Label:     "RRMenuItem;x"
        Skin Indicator: "RRMenuItem;x"
        Skin Command:   "RRMenuItemSave;key;(menuitem)"
        Skin Indicator: "RRMenuItemSelIcon" shows icon(if any) of selected item in the MenuItemSet.Skin List
        User Variable:  "RRMenuItemKey"
        Skin Command:   "RRMenuNext" goes to next menuX.skin (looping)
        Skin Command:   "RRMenuPrev" goes to previous menuX.skin (looping)
    + Skin Indicator; "RRMediaInserted" is true when a disc is inserted into the media drive
      (must have some filesystem on it \ volume name)
    * Skin Command; "plginmgr" now "RRPluginMgr" (alias of "Load;pluginmgr.skin")
    3/5/2012
    + Skin Command; "CLPOS" sets selection position (1 - number of items)
    + Skin Command; "ListPos" sets selection position of current selected list (1 - number of items)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thank you kind sir for another RR fix. What are we tackling next? If you need a tester for 6 screen support i'm your guy
    Live mp3Car Facebook Chat
      Great thanks for this new version :-)
        What is this new issue with the video option ?
        When i click on the video command that load well the video screen but also a folder where RR is installed !
          I have modified the launch path 'LaunchPath=D:\Program Files\Ride Runner\Launch' but RR try always to load calc or notepad from LaunchPath=C:\Program Files\Ride Runner\Launch and not found them .
            i have no idea what you're talking about, there is NOTHING new with the video option...
            i dont even know what a video option is
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              btw... you should move to profile mode, your folder looks a complete mess
              (yea, im picky i like organization!!!)
              I have set my launch path to...
              LaunchPath=E:\RRTest\Launch
              and it works fine...
              its not looking at the old location (which i temporarily renamed)
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Sorry , i speak about the video command !
                But i don't understand why i haven't this issue now !
                All is ok now !
                  For my tests (xp sp3 only), i prefer to use the normal mode and my launchpath isn't seen !
                    i tested it here... and its simplistic... all it does it set the initial Directory path of the List on the skin named "launch.skin"
                    hardly any code in RR related to launch path, maybe 4 lines total
                    im sure u will figure it out...
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      Pretty sure someone had mentioned it before but in case that you did not know the title of the thread says "2011".
                      No big deal but thought it might it might confuse some of the new peeps to the forum looking for the latest version.
                      Win 7 Pro 64bit, 4gb DDR2 Ram, q6600 Processor, Solid state drive & 7200 drive, Andrea mic, Sirius, DE HD Radio, Opus power supply, 10.4" touchscreen.
                      1.)Orion 2500d Amp
                      1.)Orion 15" h2 Sub
                      1.)Orion 8004 Amp
                      2.) Sets Orion Components - P-SERIES
                        I was surprised how long it took for somebody to say something.
                          What's the date?
                            I have a problem with the function play / pause.
                            When I play music with the shuffle function is true when I resume playing after a pause, the song restarts at zero.
                            Thanx
                              Thanx
                              not here....
                              I tested with RR ver 4/6/2012, WINAMP as PLAYER, CARWINGS as skin
                              noticed i provided info
                              i put songs in, pressed shuffle... went to next track... (whcih was random)... press play/pause("PLAY" COMMAND)... it paused.. press play/pause, it resumed
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
