Getting crazy with an indicator
  • Getting crazy with an indicator
    hi all, i got a little problem and i can't find a solution
    i'm trying to make an indicator that switch ON/OFF when a cd/dvd is inside the reader, the problem is that the indicator is dinamic so i need the command if ride runner has it.
    So the problem is that i can't find the indicator under the list object.txt..i've just found:
    "CDMUTE" - CD Mute
    The question is: The command exist or have to be made manually? using "ONMEDIAINSERT" and "ONMEDIAREMOVED"
    Any suggestion is apreciated Thanks you
    all you want to know is if there is a CD in the drive?
    easy.. read history.txt
    + Skin Indicator; "RRMediaInserted" is true when a disc is inserted into the media drive
    (must have some filesystem on it \ volume name)
    note, media drive, you have to have that set too, rrconifg...
    MediaDrive=
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      ahh thanks so much i think is better to read the hystory thant objects.txt
      Thanks again
        objects.txt isnt part of RR, its for skin editor, which is really a 3rd party program... while bluezx3 does update it from time to time, its FAR from perfect
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
