WINAMPEQ not working?
  • WINAMPEQ not working?
    Perhaps I'm using it wrong but I cannot get "WINAMPEQ" to toggle the eq/preamp on and off. If I send the command from skinner tool I get: "Command Not Executed: WINAMPEQ". Is there a setting on my machine? Both my dev machine and the car machine don't seem to work. "AUTOEQ" does work though for example. And yes, I am using carwings.
    OBSOLETE command, since its its player specific "Winxxxx"
    "PlayerEQ" is the proper command
    from history...
    2/12/2012
    # Skin Command/Indicator "PlayerEQ" correctly toggles player EQ on/off, and shows correct state.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      Thanks. Suav used it in the Elite skin and I only searched the skin command file. Probably should get removed if it no longer works. Now to fix the indicator that doesn't work either.
      Actually, seems like "WINAMPPREAMPMUTE" which is used in the elite skin and listed in the skincommands doesn't work either. It returns false no matter what state the preamp/eq is in. Is there a new command for this indicator?
        there is no such function as winamp preamp mute... it never did anything, and is removed, see history.txt
        ALWAYS READ HISTORY.txt, the skin commands text file isnt always updated..
        still looking for that volunteer to completely take over RR documentation
        usually when people post a command/label/indicator, 1st place i go to is history.txt
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          OK. Is there any way to determine if the preamp/eq is on or off?
            yes... the indicator "PlayerEQ" , btw its also a clickable indicator... ie you dont need a button with that command on it
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              NICE! Thanks mitchjs!
