RR 05-01-2012 Release
  • RR 05-01-2012 Release
    May! bring on spring!
    Download Here: http://www.nisuautomotive.com
    Not too much new, mostly tweaks of existing stuff, some additions for Dynamic Menus
    a cleanup on id3 tags internally, made sure id3 tags are read based on id3 setting not the
    show in list setting
    GET THE UPDATED SKIN EDITOR TWO POSTS BELOW
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    4/25/2012
    * Sirius and XM Radio Artwork updated (thanks to suavecito)
    4/22/2012
    # SkinEditor updated, see its history file
    4/21/2012
    # Skin Command; "AddToList" now supports unicode when adding to ".m3u8" file
    ! Internal Playlist / Tag Management
    * Skin Label "TRACKNAME" clean up
    4/20/2012
    # fixed issue causing video/dvd player screen from loading, causing OSD to display
    4/18/2012
    + Dynamic Menus: (see forum posts)
    	Skin Label: "RRMenuItemSelDesc" shows Description(if any) of selected item in the MenuItemSet.Skin List
    4/17/2012
    # Skin Label; "TRACKNAME" format is based on "ID3ListFormat" setting, it was in some places, now in all.
      (Future: settiing "ID3TrackNameFomat")
    + tweak to winamp player module, if winamp is closed before RR is exited (OS shutdown)
      the RRPL will be the last one that winamp saved.
    4/15/2012
    # If player was set to stay open at rr exit and paused, audio resume failed at start of RR.
    4/11/2012
    + Dynamic Menus:
    	User Variable:  "RRMenuList" holds the file that will be used for the
    	                menu list picker ("MenuItemSet.skin"), relative to SKINPATH
    					defaults: menu.lst
    	ex: SetVar;RRMenuList;menu.french.lst
    	    SetVar;RRMenuList;menuGreenIcons.lst
    		SetVar;RRMenuList;$THEME$\menu.lst
    4/7/2012
    # Assure full tags are pulled on the "now playing" track
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Thanks for this new version .
    I have an issue with the skin editor that don't see the drop shadows options on the labels !
    The version 0.7.8 hasn't this issue !
      yea... i myself dont work on the skin editor...so i dont know my way around it, but good news, i think the fix is simple
      try this one... let me know
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        Mitchjs, now the id3tags work well. Fine business!
        OT: sorry, but I have read your PM only today.
          It's ok but this is the 0.7.8 version !
            its the newest one i know of...
            trust me it 0.7.9, dispite of what is says
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              thanks for the relase mitchjs i'm going to install it tomorrow or the day after
                Mitch,
                I've installed "Chrome" browser on a test lappy today, and was wondering if RR will support this browser in future update.
                The chrome browser doesn't close when exiting screens and upon closing RR,.......(using Carwings of course).
                I been trying out "Gooveshark Mobile (Beta)" ....see below,
                which uses a browser that supports html5, Firefox and Fennec I think does not?
                I've been trying to use GS with FF with no joy. So now chrome will be my choice for my CarPC.
                I don't like to use "IE".
                Thanks bud.
                  Anyone else having trouble downloading the software?
                    does Chrome have a SDK? and can be used like IE as an object... (prob not, but if you want to look...feel free)
                    so i have no plans to make real support for Chrome, ie like RR Web Browser plugin
                    but as for embedding Chrome, no plans too..
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      i'm using mobile opera it's possible to support also the flash on it, it's perfect in my opinion
                      (is possible to see youtube, go to any website view them in mobile and desktop mode and is touch friendly)
                        Thanks Mitch
                        I like "TRACKNAME" because I have some songs with no id3tag..
                          A 'WebKit' for Chrome exist !
                          With it's possible to create a web form with chrome and not ie.
                          But i have tried to use this webkit that run very well with an exe but not into a plugin .
                          I suppose that my issue is that the webkit use the framework 4.0 and RR accept only 2.0,3.0 and 3.5 !
                            Since updating or a coincidence, RR is opening two separate instances of Winamp. Tried with Carwings Dynamic Lite and DFX5. Even if i close one instance trying to play any music hangs and crashes RR. Any ideas? This is a fresh install of RR 5-01-2012
