Navigator 11 from Mapfactor
  • Navigator 11 from Mapfactor
    Is there anyway to get the free version of Navigator 11 from Mapfactor to enbed in RR? I selected External Mode in RRConfig and in Application path I put "C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\ProgramData\Navigator\11.0\atlas_pcn_fre e.idc' and I put PCNavigator for the Windows Title. But nothing happens when I try to launch it from within RR using Carwing_Dynamic_Lite. Also I am using the latest version of RR. I really like this navigation program plus it's free so I would love to use it within RR if at all possible.
    thanks.
    Hi
    Yep my settings for 800X600 res
    in the RR.ini file under the Navigation tag
    Code:
    [Navigation]
    GPSMode=2
    GPSPath=C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc --window_border=no --window_position=0,73,800,453
    GPSName=!BarneyMainWndCls!Navigator
    and you need to add
    Code:
    A,0,70,800,453,
    C,0,70,800,453,
    to the external_gps.skin(the name of the gps skin you are using) file
    any probs or more info needed yell
    Wozza
      I have tied to define Pc Navigator into the new RR dynamics menu but Pc navigator is note loaded because it has need some quotes !
      This is my try:
      I have added into my exectbl.ini file on the 'ONSKINSTART' line:
      "ONSKINSTART","$default$||PresetLoader||SAY;Le Système Multimédia est prêt||SETVAR;QUOTES;""
      PC_NAVIGATOR 11 = "Load;external_gps.skin;Pc Navigator;$QUOTES$D:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe$QU OTES$ --atlas='D:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc' --window_border=no --window_position=0,73,800,453;!BarneyMainWndCls!Nav igator",PC NAVIGATOR 11,Icons\GPS.png,,Pc Navigator 11 is selected
      I have also tried:
      PC_NAVIGATOR 11 = "SETVAR;QUOTES;"||Load;external_gps.skin;Pc Navigator;D:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe$QU OTES$ --atlas='D:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc' --window_border=no --window_position=0,73,800,453;!BarneyMainWndCls!Nav igator",PC NAVIGATOR 11,Icons\GPS.png,,Pc Navigator 11 is selected
      Where is my error svp !
        Thanks Wozza I will give that a try.
          dude, make a damm batch file
          pcNav.cmd
          in that have all that crap!!!
          (--atlas='D:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc' ) and such and such
          -Thanks
          Mitch
          www.rush2112.net
          Sun, Come shine my way
          Wind, Carry me home
          The piece of me that died
          Will return To live again
            Hi Pierrotm
            No Idea I try to keep it simple..the above method isnt perfect but appears to work ok
            I havnt tried it whilst driving yet as my carpc is still all over the work bench
            Wozza
              where do I find the RR.ini file?
                C:\Program Files\RideRunner\rr.ini
                  Bad answer...
                  If you installed RR in "Profile" mode, then its in Docs\RideRunner\Config\rr.ini, otherwise you installed it in "Legacy" mode, and will be in the above mentioned place.
                  Next in line: RRMedia v2.0
                  DFX 5.1.1 Skin
                  Appstore Link
                  My RideRunner Plugins
                  RRMedia
                  RRExtended
                  DFXVoice
                    Originally posted by Blue ZX3 View Post
                    Bad answer...
                    Blue, you have always the good answer
                      Hi Feiko
                      The above wont work with the latest ver of RR only the April or earlier vers
                      The latest ver has added support for nav11 but I couldn't get it to work(not that I spent much time with it ) so no idea how
                        Also running latest version of RR and have tried every possible way to get PC NAV 11 FREE to work but no luck, did see this in the Extras in RRCONFIG
                        [Extras]
                        c:\program files\navigator11\pc_navigator\pc_navigator.exe*--atlas='C:\ProgramData\Navigator\11.0\atlas_pcn_fre e.idc'
                        testpluginvar=defaultValue
                        radiouasinput=0
                        xmuasinput=0
                        But no idea how its implemented, pity as the NAV is a bit of a deal breaker when it comes to front ends
                          that line is not going to do anything...
                          -Thanks
                          Mitch
                          www.rush2112.net
                          Wind, Carry me home
                            I know its not implemented, was just showing it had been added to the latest rrconfig app. Can Previous builds be found online as may go back to a version that could support PC NAV 11 FREE
                              the current build supports pc nav 11 FREE
                              its just about setting it up
                              not hard
                              -Thanks
                              Mitch
                              www.rush2112.net
                              Wind, Carry me home
