SendKeys
  • SendKeys
    Is it possible the sendkeys command was broken in the new version of RR?? Specifically, sendkey buttons to call diferent functions in iGuidance are not working. I though it was only in DFX5 but they don't work in several other skins (DFX4, iDriveT, Void).
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    nope, no change to that code...
    sendkeys only works if that window is the ACTIVE window for input
    to me sendkeys blows in all cases, very unreliable...
    in anycase, if you give me an example of real usage, i can test...
    and your going to tell me when you hit say "3d" in dfx5, it doesnt work...
    well it does for me and that seems to be a sendkey as per skintool
    SENDKEY;"{3}","
    infact they all work, BTW i never looked at DFX5's support for IG, NICE!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
      brings up a point
      this is a better way
      ACTIVATE;IGuidance||SENDKEY;3
      add "ACTIVATE;IGuidance||" infront of all those commands, to ASSURE(well resonably assure) they actually go to IGuidance
      but you know, i can make a better SENDKEY Command...
      ALL THIS DOESNT apply, keep reading...
      -Thanks
      Mitch
      www.rush2112.net
      Wind, Carry me home
        it just gets more interesing look at this code
        If (InStr(1, CurSCR, "gps") <> 0 And LCase(GPS_NAME) = "iguidance") Then
        Activate iGhwnd
        SendKeys Key, True
        Else
        that means, DFX5 skin is flawed since its skin name is names "iguidance_wide" no where is "gps" in it...
        so it wont activate the iguance window!
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          course i dont like any of that code, and will rewrite some of it
          -Thanks
          Mitch
          www.rush2112.net
          Wind, Carry me home
            you know too, i see issues in DFX5 too...
            inconsistency
            external_gps, its going to work fine with the activate code
            but... for 3d it sends out
            B,2,77,72,71,"SENDKEY;"{3}",""
            where in the WIDE (iGuidance_wide.skin)
            B,196,1,99,70,"SENDKEY;3",""
            also see a dupped issue in wide
            DFX5 needs review
            for current code to focuse on IG
            the skin should be called
            iguidance_wide_gps.skin
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              NEW COMMAND
              SENDKEYX
              SENDKEYX;keys
              will send key, but 1st will target embedded window on current screen (in our example iguance) skin name not matter!!
              so... SENDKEYX;3
              will send the 3 key to the embedded app (in our case 3 is toggle 3d)
              also!!!
              SENDKEYX;keys;windowname
              you can with one command, activate a window, and then send keys to it (why you need to do this i dont know, but you can)
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                Originally posted by Enforcer View Post
                I think the issue may be your recent enhanced embedding upgrade
                NOPE!
                the problem here is partial DFX5
                and well we dont know what else he really did
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  simple fix up for now... if you dont get the new rr, and USE THE NEW MUCH IMPROVED sendkeyx is
                  fix the naming of the skin file to have _gps in it
                  so
                  like "IGUIDANCE_WIDE.skin" named "IGUIDANCE_WIDE_GPS.skin"
                  then a old sendkey will know that if the name has "gps" in it, and iguidance is the the GPS_NAME it will activate the iguidance window
                  OR
                  BETTER
                  get the new RR *6/21/2012 or newer
                  and change sendkey to sendkeyx
                  and fix up the skisn does {3} should be just 3 for 3d
                  m
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    also
                    "ACTIVATE||SENDKEY;3"
                    would work... activate command acticvates the embedded window on current screen
                    so just adding that infront of any send key would work too
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
                      good thing about the new sendkeyx, u can use it in SKINTOOL
                      the old one would try to send keys to skintool itself
                      so.. on the iguidance_wide.skin, in skintool, "SendKeyx;3" would activate ig and send 3, and keep it active!
                      (im debating if i want to return focus of its "skintool" just cause i love skintool!)
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        also few errors in DFX5 skin (looking at wide now)
                        whats
                        B,1,1,95,70,"SENDKEY;"{enter}",""
                        it should be
                        B,1,1,95,70,"SENDKEY;{enter}",""
                        some oddball extra "
                        lots of clean up
                        and now should be SENDKEYX
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          Thanks. Will test the changes and report back.
                          P.S. Got your PM.
                          OLD SYSTEM (DEAD)
                          M2-ATX Power Supply
                          Windows XP SP3
                            Originally posted by mitchjs View Post
                            NOPE!
                            Well I'm basing on him mentioning it didn't work in the iDriveT skin when it used to.
                            Now I know the iDrive skins don't have activate before the sendkey (although the buttons for other nav engines do) they do have gps in the skin name.
                            (unless of course he didn't use the config in iDrive to change the Nav to iGuidance)
