RR freeze delay after hibernate resume
  • RR freeze delay after hibernate resume
    In most cases (99%), when the computer returns from hibernation, the screen shows the RR (The last DFX screen i was before turning of the car), but it is "no answer", it show the mouse button (even i set to hide mouse button), if i press one button i have no answer, no play, no pause, no next, nothing, no button press change, nothing, the title of the music in the top, the album, normally its rolling in the bar to show all the name, but in this time after the hibernation return, the name/title/album is freezed(after the windows boot, about 20-80 seconds showing the rr last screen, it return to work and mouse button disappear)... i cant understand what is this, my windows is new, fresh with speed tweaks, "fast computer", i saw other video and they dont have any big delay like i have
    Configs:
    * Windows 8 (I used windows 7, tinyxp, and i had the same problem) (with windows 8 i have others problems too, its show a minimized error screens "Not find musics.txt" but the music playlist work normally, so i dont care about this screen since everyting after the freeze works normally, and windows 8 small screen to show retro menu in the left botton of the screen, but this problems dont make impossible to use the rr, only the freeze delay that are annoying)
    ----> Why windows 8? it has a really fast boot up, but the freeze time after, i had in windows 7 and tiny xp
    * Intel d510mo
    * Skin DFX
    * 2GB Ram DDR2 800mhz
    * HD 500GB
    im dreaming or is possible to make the things works faster like factory carpcs using windows CE? or something near without this freeze after the windows boot?
    Do you have hibernate resume delay setting set high in rrconfig? Are you using a solid state or standard hard drive. Biggest difference between start/resume times for me has been the addition of a solid state drive.
    Live mp3Car Facebook Chat
      hibernate delay in rrconfig = 3seconds, im using a hard drive... but the problem is not in the boot up,, its after, i will do a video to show what im saying!!
        no need of a video, i changed the skin to Carwings, and it work normally, fast after hibernate, i cant understand why DFX take so much to "full load"
        so im using Carwings now until i find one way to make DFX more faster ;/
          I think what is missing is way more details! I of course use DFX in the car everyday using standby and on occation have used hib too with no issues for the most part(OS: TinyXP Rev9). I have in the past, seen what your talking about where you just cant do anything until that xx secs elaspes and then all is good... I wish I had a straight up answer to fix it or where to look for ya but I don't.
          Try attaching a debug log session from both skins and see where that leads.. Your also comparing a very simple skin, to a very complex one...which does not help either.
          Next in line: RRMedia v2.0
          DFX 5.1.1 Skin
          Appstore Link
          My RideRunner Plugins
          RRMedia
          RRExtended
          DFXVoice
            DefaultBR,
            I did a lot of research on a related issue. Quick question: Do you have the gen_resumer.dll in your plugin folder? Once I removed this plugin, I stopped having the issue with RR locking up on me. My original issue was that when I started DFX or CarWings, RR would lock up as soon as I touched any button. After checking the debug, I found that it errored out on the ding.mpg. Initially I thought the file was corrupt, but that was not the case. If you have the resumer plugin, disable it and see what results you have.
            Bobby
