RR 07-01-2012 Release
  • RR 07-01-2012 Release
    July, dam 2012 flying by...
    Download Here: http://www.nisuautomotive.com
    A new option for Sliders....really nice for Mice users (or people still without a carpc (me))
    myself using mode 1(loose mode)
    mode 2, is loose mode with roaming, ie your finger can move off the slider, really interesting on a screem
    with a bunch of sliders, like an EQ screen.
    I will add these new options to RRCONFIG, when i get a few mins, been very busy of late
    well between a new Plugin; Carnetix P2140, that i will release shortly, only documentation holding it up
    Highlights:
    • + NEW Setting; "rrSliderMode=x", Where x = 0-2 (defaults to 0).
    • + NEW Skin Command; "SendKeyX"
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    6/24/2012
    # Indicators with NOT(-) prefixed to it, sent into plugins incorrectly.
    6/20/2012
      0 = Default behavior.
      1 = Loose mode.
      2 = Loose mode with roaming.
    # Fixed issue with Map Factor's PC Navigator 11 support when resizing skins.
      ex. "SendKeyX;3                 - sends the 3 key stroke to the application currently embedded on current screen.
      ex. "SendKeyX;hello;notepad"    - sends the key strokes of "hello" to the application window named "notepad".
                                        (This will return focus back to embedded window if any)
    06/19/2012
    # Fixed issue with labels that were defined in .skin as the same as internal size,
      causing incorrect background painting on label.
    06/17/2012
    # Slider out of bounds values passed into plugins.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
      [/CODE]
      Can't wait to see if it's worthy.
      Still need sleep.
      TruckPC - gutted, being used for test setup
      BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
      BlazerPC - Nexus 7 with Timur's USBROM
        The sliders run very well, and this was a point that i didn't like into RR . Now it's coool
          Still need sleep.
          Well I can assure it is worthy!
              Hi Mitchjs,
              I still have the same problem with the shuffle function. I tried with skin CARWINGS and without plugin installed, I use windows 7.
              If the shuffle is enabled and that I relaunch playing the song when it was paused, the song starts from the beginning.
              Thanx
                not me, when i relaunch rr, the song resumes (in pause) at the right possition
                with RR 7/1/2012, with carwings , with WINAMP as player
                also provide some real info btw!
                RR.ini:
                AudioShuffle=Last
                DEBUG:
                Code:
                7/15/2012 1:13:28 PM: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
                7/15/2012 1:13:28 PM: INFO: LoadResume() - Reading resume data from C:\Users\mitchjs\Documents\RideRunner\Cache\resume.ini
                7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - music player: PLPosition=4  TrackPosition=-54831
                7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - player volume should be 0: 0
                7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - player should be playing: PLAYING
                7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - Player.GetTrackLength: 291000
                7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - Player.SetTrackPosition: 54831
                7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - no fadeinvolume, player volume should be 255: 255
                7/15/2012 1:13:28 PM: INFO: CheckResume() - Resuming to music player: PAUSED
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  ..just spotted in changelog :
                  mobile phone support - does that mean no need for mp.net plugin anymore ? cheers
                    Hi Mitchjs,
                    It's not when I relaunch RR but when I pause and play the song.
                    with RR 7/1/2012, with carwings, with WMP as player
                    RR.ini
                    AudioShuffle=last
                    DEBUG:
                    Code:
                    18/07/2012 12:43:22: Start -- Version: 01/07/2012
                    18/07/2012 12:43:22: OS Type: Windows 7
                    18/07/2012 12:43:22: FileManager: FileMode = Legacy
                    18/07/2012 12:43:22: FileManager: mypath = D:\Applications\RideRunner\
                    18/07/2012 12:43:22: FileManager: ProfilePath = C:\Users\Administrateur\Documents\RideRunner\
                    18/07/2012 12:43:22: Start Sequence: Starting Player...
                    18/07/2012 12:43:22: PLAYER: Initialization creating object
                    18/07/2012 12:43:24: PLAYER: Started
                    18/07/2012 12:43:24: PLAYER: WMP Version: WMP (12.0.7601.17514)
                    18/07/2012 12:43:24: PLAYER: Initialization complete
                    18/07/2012 12:43:24: Start Sequence: Starting Radio Device...
                    18/07/2012 12:43:24: Start Sequence: Starting Serial Devices...
                    18/07/2012 12:43:24: Start Sequence: Starting Mixer...
                    18/07/2012 12:43:24: VMC---> Set object successful
                    18/07/2012 12:43:24: VMC---> SOURCE: Mixer line #1: "Microphone"
                    18/07/2012 12:43:24: Start Sequence: Starting Speech...
                    18/07/2012 12:43:25: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
                    18/07/2012 12:43:25: Plugin Manager: loading Global Plugins...
                    18/07/2012 12:43:25: Plugin Manager: Plugin Found: SkinTool
                    18/07/2012 12:43:25: Plugin Manager: Plugin loaded (Global): SkinTool
                    18/07/2012 12:43:25: Plugin Manager: Plugin Found: Weather
                    18/07/2012 12:43:25: Plugin Manager: Plugin loaded (Global): Weather
                    18/07/2012 12:43:25: Plugin Manager: loading Global Plugins Completed.
                    18/07/2012 12:43:25: LoadSkin: D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\
                    18/07/2012 12:43:25: Plugin Manager: loading SkinDir Plugins...
                    18/07/2012 12:43:25: Plugin Manager: loading SkinDir Plugins Completed.
                    18/07/2012 12:43:25: INFO: LoadKVPFromFile() - Reading KVP data from D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Menu.ini
                    18/07/2012 12:43:25: Enter Exec: Faux, menu.skin, "ONRESTORED", Faux
                    18/07/2012 12:43:25: Que Exec: Vrai, menu.skin, "ONRESTORED", Faux
                    18/07/2012 12:43:25: Que Exec: Vrai, menu.skin, "ONSTART", Faux
                    18/07/2012 12:43:25: Que Exec: Vrai, menu.skin, "ONLINE", Faux
                    18/07/2012 12:43:25: Leave Exec: Faux, menu.skin, ONLINE, Faux
                    18/07/2012 12:43:26: Global Hotkey: Successfully registered keycode:2112
                    18/07/2012 12:43:27: PLAYER: Restored rrpl.m3u8
                    18/07/2012 12:43:27: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
                    18/07/2012 12:43:27: INFO: LoadResume() - Reading resume data from D:\Applications\RideRunner\resume.ini
                    18/07/2012 12:43:27: INFO: AudPlayerStart() - music player: PLPosition=0  TrackPosition=-5560
                    18/07/2012 12:43:27: INFO: AudPlayerStart() - player volume should be 0: 0
                    18/07/2012 12:43:27: Enter Exec: Faux, menu.skin, , Faux
                    18/07/2012 12:43:27: Que Exec: Vrai, menu.skin, "ONSKINSTART", Faux
                    18/07/2012 12:43:27: Que Exec: Vrai, menu.skin, "ONSOURCECHANGE", Faux
                    18/07/2012 12:43:27: Leave Exec: Faux, menu.skin, ONSOURCECHANGE, Faux
                    18/07/2012 12:43:28: Enter Exec: Faux, menu.skin, , Faux
                    18/07/2012 12:43:28: Que Exec: Vrai, menu.skin, "ONSONGSTART", Faux
                    18/07/2012 12:43:28: Leave Exec: Faux, menu.skin, ONSONGSTART, Faux
                    18/07/2012 12:43:28: INFO: AudPlayerStart() - player should be playing: PLAYING
                    18/07/2012 12:43:28: INFO: AudPlayerStart() - Player.GetTrackLength: 261512
                    18/07/2012 12:43:28: INFO: AudPlayerStart() - Player.SetTrackPosition: 5560
                    18/07/2012 12:43:28: INFO: CheckResume() - Resuming to music player: PAUSED
                    18/07/2012 12:43:30: Enter Exec: Faux, menu.skin, "ONBTNPRESS||PLAY", Faux
                    18/07/2012 12:43:30: Que Exec: Vrai, menu.skin, "ONBTNPRESS||PLAY", Faux
                    18/07/2012 12:43:30: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
                    18/07/2012 12:43:30: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
                    18/07/2012 12:43:30: Que Exec: Vrai, menu.skin, "PLAY", Faux
                    18/07/2012 12:43:30: Executing: PLAY
                    18/07/2012 12:43:30: Leave Exec: Faux, menu.skin, play, Faux
                    18/07/2012 12:43:37: Enter Exec: Faux, menu.skin, "ONBTNPRESS||PLAY", Faux
                    18/07/2012 12:43:37: Que Exec: Vrai, menu.skin, "ONBTNPRESS||PLAY", Faux
                    18/07/2012 12:43:37: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
                    18/07/2012 12:43:37: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
                    18/07/2012 12:43:37: Que Exec: Vrai, menu.skin, "PLAY", Faux
                    18/07/2012 12:43:37: Executing: PLAY
                    18/07/2012 12:43:37: Leave Exec: Faux, menu.skin, play, Faux
                    18/07/2012 12:43:40: Enter Exec: Faux, menu.skin, "ONBTNPRESS||PLAY", Faux
                    18/07/2012 12:43:40: Que Exec: Vrai, menu.skin, "ONBTNPRESS||PLAY", Faux
                    18/07/2012 12:43:40: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
                    18/07/2012 12:43:40: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
                    18/07/2012 12:43:40: Que Exec: Vrai, menu.skin, "PLAY", Faux
                    18/07/2012 12:43:40: Executing: PLAY
                    18/07/2012 12:43:40: Leave Exec: Faux, menu.skin, play, Faux
                    18/07/2012 12:43:51: Enter Exec: Faux, menu.skin, "ONBTNPRESS||EXIT", Faux
                    18/07/2012 12:43:51: Que Exec: Vrai, menu.skin, "ONBTNPRESS||EXIT", Faux
                    18/07/2012 12:43:51: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
                    18/07/2012 12:43:51: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
                    18/07/2012 12:43:51: Que Exec: Vrai, menu.skin, "EXIT", Faux
                    18/07/2012 12:43:51: Executing: EXIT
                    18/07/2012 12:43:51: Enter Exec: Faux, menu.skin, "ONEXIT", Faux
                    18/07/2012 12:43:51: Que Exec: Vrai, menu.skin, "ONEXIT", Faux
                    18/07/2012 12:43:51: Leave Exec: Faux, menu.skin, ONEXIT, Faux
                    18/07/2012 12:43:51: Shutdown: (1)
                    18/07/2012 12:43:51: Shutdown: (2)
                    18/07/2012 12:43:51: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
                    18/07/2012 12:43:51: Shutdown: (3)
                    18/07/2012 12:43:51: Shutdown: (4)
                    18/07/2012 12:43:51: INFO: SaveResume() - Saving resume data to D:\Applications\RideRunner\resume.ini
                    18/07/2012 12:43:51: INFO: LoadResume() - Reading resume data from D:\Applications\RideRunner\resume.ini
                    18/07/2012 12:43:53: Plugin Manager: Warning Plugin skintool does not support Terminate Method
                    18/07/2012 12:43:53: Plugin Manager: Warning Plugin weather does not support Terminate Method
                    18/07/2012 12:43:53: Plugin Manager: ALL Plugins unloaded.
                    18/07/2012 12:43:53: Shutdown: (5)
                    18/07/2012 12:43:53: Player is running
                    18/07/2012 12:43:55: Shutdown: (6)
                    18/07/2012 12:43:55: Shutdown: (7)
                    18/07/2012 12:43:55: OSUnloadMode: 1
                    18/07/2012 12:43:55: Global Hotkey: All keys unregistered
                    Thank you
                      looks good to me, its paused, and positioned
                      and i tested WMP myself now, works, fine, rr starts up with track in pause
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
                        Sutff.Hunter, ?? what changelog?
                        -Thanks
                        Mitch
                        www.rush2112.net
                        Wind, Carry me home
                          Current Status of release:
                          Phone Control
                          what exactly is that mean
                            the problem is solved.
                            I don't know why, I found an old rr.ini which functioned normally. When I compared with rr.ini posing problem, the only difference I saw is "CircularList". In rr.ini posing problem CircularList = true, so I change it but no effect, I reset it to true and now the shuffle working properly ????
                            Thanx again Mitchjs
                            Edit: false joy because when I save another change in rrconfig the problem returns.
