foobar2000 not working
  • foobar2000 not working
    So right now I am trying to check out RideRunner and so far I am VERY impressed. Its like day and night compared to CF so far. So many awesome options, wow.
    However, Ive hit my first wall already. I want to use foobar2000 as player but it wont work. It simply wont play any music. I can select the songs, but it wont play. If I use foobar2000 externally, it works fine.
    When I choose WMP as the player, it works without problems.
    Did I miss something?
    Also another question: Is there a way to customize the volume increment value? Its 5% right now, but I would like it to be 1%.
    Thanks!
    Well, I have noticed it actually plays, but for some reason foobars volume is always at 0 at start. I always have to manually set it to 100% in foobar and then switch back to riderunner and then it works. On the next restart it will be at 0 again, though.
      not for me... and ill provide some actuall useful INFO
      Windows 7 x64
      RideRunner 7/1/2012
      Foobar2000 v1.3, no addional plugins, other that AC3 input
      SKIN: Carwings
      and NO FADE VOLUME (always a issue)
      -Thanks
      Mitch
      www.rush2112.net
      Sun, Come shine my way
      Wind, Carry me home
      The piece of me that died
      Will return To live again
        and what volume are you talking about? (the increment question) any time you talk about audio, you better disclose OS
        -Thanks
        Mitch
        www.rush2112.net
        Wind, Carry me home
          Windows 7 x64
          foobar 1.1.13
          Riderunner 07-01-2012
          Carwings
          Just like you.
          What do you mean with master volume? Its set at 100%, but since foobars volume is at 0, I cant hear anything. I have to switch to foorbar itself and put it manually to 100, but its at 0 again after a new start.
          I also saw that the Winamp volume is at 0, and I cant move the slider at all. When I use WMP, its moveable and after a start I can see it moving automatically to 100%. Is supposed to be unmovable with foobar as player?
          Oh yeah I forgot about my other question. Forget that one, because I found out that it is 1% automatically at 10% volume and below, which is a very nice feature and works fine for me.
            BTW, the winamp slider will move automatically, when I change the volume in foobar2000 manually. But in RR itself I cant move it.
            I think I have the same problem as in this post: http://www.mp3car.com/road-runner/14...ml#post1444007
            But there doesnt seem to be a solution?
              no, i dont think thats at all related (but its so long ago, i cant remember)
              moving my WINAMP (poorly named i might add) slider on the EQ screen, does fully control the FOOBAR2000 Volume
              ALSO while your at it...
              in rr.ini make sure
              FadeInVolume=False
              -Thanks
              Mitch
              www.rush2112.net
              Wind, Carry me home
                oh, and review your DEBUG.txt
                you will see..
                Code:
                7/23/2012 11:10:24 PM: INFO: LoadResume() - Reading resume data from C:\Users\mitchjs\Documents\RideRunner\Cache\resume.ini
                7/23/2012 11:10:24 PM: INFO: AudPlayerStart() - music player: PLPosition=1  TrackPosition=9000
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> Set to new track: 2
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> To Fb2k: vol -100
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> From Fb2k: VOLUME|-100.00
                7/23/2012 11:10:24 PM: INFO: AudPlayerStart() - player volume should be 0: 0
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> To Fb2k: play 2
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> Play,  position change, playing track: 2
                7/23/2012 11:10:24 PM: Enter Exec: False, menu.skin, , False
                7/23/2012 11:10:24 PM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
                7/23/2012 11:10:24 PM: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
                7/23/2012 11:10:24 PM: INFO: AudPlayerStart() - player should be playing: PLAYING
                7/23/2012 11:10:24 PM: INFO: AudPlayerStart() - Player.GetTrackLength: 311000
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> To Fb2k: seek 9
                7/23/2012 11:10:24 PM: Que Exec: True, menu.skin, "ONSONGSTART", False
                7/23/2012 11:10:24 PM: Leave Exec: False, menu.skin, ONSONGSTART, False
                7/23/2012 11:10:24 PM: INFO: AudPlayerStart() - Player.SetTrackPosition: 9000
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> To Fb2k: vol 0
                7/23/2012 11:10:24 PM: Foobar2000 AudPlayer---> From Fb2k: VOLUME|0.00
                7/23/2012 11:10:24 PM: INFO: AudPlayerStart() - no fadeinvolume, player volume should be 255: 255
                yes 0 is max volume (0db)
                -Thanks
                Mitch
                www.rush2112.net
                Wind, Carry me home
                  feel free to ATTACH a debug.txt of one session...
                  -Thanks
                  Mitch
                  www.rush2112.net
                  Wind, Carry me home
                    It was FadeInVolume that was on True.
                    Thanks a lot!
                      ill look at that, but its always been an issue, and just to the nature of pc audio, i always recomend it to disabled
                      -Thanks
                      Mitch
                      www.rush2112.net
                      Wind, Carry me home
