Bring All Ready Running Program into RR Skin Screen
  • Bring All Ready Running Program into RR Skin Screen
    How do I bring an already running program to a RR screen. I am using on skin start to start Dash Command, but the only way I know how to get it in RR is to Run c\programs\dashcommand. The problem is it starts a seperate instance.
    Thanks.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
    if you want to embed the window, just use the RUN; command, you only need the correct window name
    Code:
    LOAD;skinname.skin;;;WINDOWNAME
    in other words, just dont include the exe path, if is already running, and if it has a window active, RR will find it and embed it. look on the skincommands for the LOAD command to see how it works.
    BASSRR ==> [Audio Player/MusicDB/Cd Player/Ripper/Rate/Internet Radio/Audio Capture/Youtube Video]
    RRTube ==> [View/Download Youtube Videos]
    WifiMan ==> [Wifi Manager]
    RRec ==> [Audio Capture]
    If You Want To Be Given Everything, Give Everything Up ...
    Bird York -- In The Deep --
      Thanks for the response El Camino. I also found that i needed to include the window name in my ONSKINSTART command in the Exectbl.ini.
      Code:
      "Dashcommand","RunQ;C:\Program Files\DashCommand\dashcommand.exe| -nosplash -startindashboards -title -autoconnect:"MyDashCmd"
