Songs Labels Missing in Menu Skin
  • Songs Labels Missing in Menu Skin
    Hi,
    I just upgraded my old RR (Mar 2011) ver. to July 2012 ver. on Win7 SP1(32 bit) & the included Carwings skin for testing. When the skin is started, the music (winamp) will play but the songs labels won't show in the menu.skin.
    The songs labels will only display when I go to the Audio skin & back to menu skin.
    Is there any dll files that need to be registered manually? I haven't keep up with the new RR developments & would appreciate any advice.
    Thanks.
    Intel D945GCLF2, Lilliput 629GL-70NP, GTop MTK GPS, Road Runner, DFX4, Winamp 5.13+Console+VST->HotAudio DAC->NXS 400.4 + NXS400.2 DSP Amplifiers + DSP Software Processing->Dynaudio 340 3 Way Active
    Hi
    Using RRconfig in the music sections under tags and formatting
    try Prefer ID3v1tags and check all the box's
    you may need try the others but thats what worked for me
      Originally posted by Wozza View Post
      Hi
      Thanks. I tried all combinations & no luck with it.
      The tags / albumart did showed up in the Audio player skin. So if I go to Audio & then back to menu, the tags will display correctly. I tried DFX 5.1.2 & encountered the same problem.
        many things here to consider...
        id set to perfer v2 tags, v1 are a bit out of date
        and when you start rr, if its set to resume music, then it will show tags
        if winamp is playing, maybe you installed some plugin in winamp, that really you shouldnt
        if you want music to resume
        set in rr.ini resumemusic=1 (or 2)
        1 at minimum
        other wise, technically when u run RR, and thats 0, there is no source active, therefor no tags to display
        to me 0 is bobo, and 1 is minimum setting
        as you should really always have a source active
        -Thanks
        Mitch
        www.rush2112.net
        Sun, Come shine my way
        Wind, Carry me home
        The piece of me that died
        Will return To live again
          1 at minimum
          Hi Mitchjs,
          Yes, I'm using v2 tags with resumemusic=2 & Winamp w/o any pluggins. One thing I notice is Winamp have to be playing music when RR starts. If Winamp is started in paused state, then RR will freeze.
          Here's a video of my problem with the tags :
          1. RR start, music will play without tags & the track slider moving.
          2. Going into Audio skin will display the tags & once back to Menu skin, the tags & track time will display correctly.
            please test with carwings
            also use skintool, to check the "LABELS" in question
            -Thanks
            Mitch
            www.rush2112.net
            Wind, Carry me home
              THanks, Mitch, I tried Carwings & the labels displayed correctly. Carwings is also able to run with Winamp in the paused state.
              I also used skintool to check the labels for DFX skin & its confirmed that the trackname is not dislayed in the menu skin. Only by going to Audio & then back to Menu will the trackname label display correctly.
              Also DFX startup will freeze if Winamp is not in the playing state.
              I'm still trying to resolve these 2 issues on my benchtest. Anyone out there got any recommendations?
              My PC is WIN7 SP1, 32 bits, latest flash, Netframework 3.5.1 & 4, Direct X11 & 9.0C
                If it works in Carwings but not in DFX you need to ask the question in the DFX skin thread.
                But first compare the labels in the menu.skin's of both skins to see if there is any difference there.
                  Yes, i did lots of tests & confirmed Carwings is working fine with Win7.
                  Hope to find a solution over at DFX section, thanks.
                    ok... its hard for me to test in dfx5, so many possibities
                    i can try...what are the labels actually in question
                    -Thanks
                    Mitch
                    www.rush2112.net
                    Wind, Carry me home
